Community-Contributed Guide
Tools
×4
Spudger4.9
Remove the protective cover to expose the battery and detach the power connector.
Lift the screen cover to expose three screws holding the plastic case together.
To lift the screen cover, use a spludger or otherwise small tool to lift the cover.
The cover is glued together, so lift the cover slightly and then use an opening pick to ensure that part doesn't get glued back
Work your way through the screen with another opening pick to unglue the cover. Leave opening picks where needed to ensure those parts are not glued back as you work your way through the cover with the opening pick
After removing the screws, take an opening pick and work your way through the case. The case has three plastic joints holding it together
As you run your opening pick through the case, these joints will pop out. They might need a small push with a spludger, if they seem to offer too much resistance
The loud speaker in the back of the case is attached to the motherboard through a connector
Lift the connector upwards to disconnect it. I find that a spludger works well, with slight nudges from side to side, as these connectors offer some resistance
The motherboard is secured to the front of the case by the plastic holders marked in blue circles.
Use a spludger to gently push these holders and pop the motherboard out of their grasp
Beware that the screen is loose, so it might fall or damage the connector cable
The screen is connected to the motherboard with the connector marked by the blue rectangle. Use a spludger to lift the black part of the connector upwards
Remove the cable and the screen
Place the new screen in the front of the motherboard and align it with the case.
Connect the new screen to the motherboard
Reassemble in reverse order of this guide
One note when glueing the screen cover back. I used 2mm electronic double sided tape, however, the existing glue should be enough to hold the cover. My recommendation is adding double sided tape, as thin as you can, on the edges of the screen and use that to glue the cover
1 Guide Comment
for anyone looking for spare screen I used a VS043T-004A (paid ~£20) and it worked perfectly fine, perfect fit and fixed our monitor cracked screen, just don't forget to reconnect the speaker when closing it!
The screen is standard so all you need is a screen with standard 40pin connector (non touch version) make sure the connector is on the correct side as tehre are 2 versions of these screen with the connector on different spots and it'll do but I can confirm 100% that ref works :)
