BaByliss Titanium T83a Battery Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
6
Past 7 Days:
48
Past 30 Days:
147
All Time:
4,553
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. BaByliss Titanium T83a Battery Replacement, Loosen housing screw at rear-bottom: step 1, image 1 of 1
      • Remove the screw at the bottom of the housing with a Phillips-head screwdriver.
      Ask FixBot
    2. BaByliss Titanium T83a Battery Replacement, Loosen rear upper housing screw: step 2, image 1 of 1
      • The upper housing screws are covered by the size adjustment. This must first be set to high via the adjustment wheel on the front.
      Ask FixBot
    3. BaByliss Titanium T83a Battery Replacement, Loosen circuit board and setting wheel: step 3, image 1 of 1
      • Remove the upper housing cover. The one below cannot be removed yet. The frame for the attachments must be removed first. This can be done more easily by loosening the adjusting wheel and the small circuit board.
      Ask FixBot
    4. BaByliss Titanium T83a Battery Replacement, Loosen the adjusting wheel from the attachment frame: step 4, image 1 of 1
      • The adjusting wheel is connected to the frame of the cutting attachments. This can be loosened with the fingers without tools when the wheel is removed.
      Ask FixBot
    5. BaByliss Titanium T83a Battery Replacement, Intermediary step: step 5, image 1 of 1
      • The picture also shows once again the connection between the attachment frame and the setting wheel.
      • Now the hair clipper should be disassembled as shown in the picture.
      Ask FixBot
    6. BaByliss Titanium T83a Battery Replacement: step 6, image 1 of 1
      • Loosen the screws of the motor
      • Remove the motor from the housing
      Ask FixBot
    7. BaByliss Titanium T83a Battery Replacement: step 7, image 1 of 1
      • The batteries can now be soldered to the board.
      • New batteries can be found here.
      Ask FixBot
Work through the steps in reverse order to reassemble your deivce.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
Mehonidas
247 Reputation
1 Guide authored
3 Guide Comments
Oberen Gehäusedeckel abnehmen: das schaffe ich leider nicht, gibt es da einen Trick?
krauss - Reply Share
Hallo Krauss,
nein du musst nur die 3 Schrauben auf der Rückseite lösen. Eine unten und die zwei unter der Größenjustierung. Sind die Schrauben alle richtig raus? Bei mir hing eine drinne fest. Vielleicht am Stellrad etwas drehen, die Größenjustierung ist das fummligste an der Sache.
Gruß Meho
Mehonidas - Reply Share
Super danke für die Info, habe einfach etwas fester dran gezogen, und am weißen Stellrad gedreht (gewackelt) jetzt ist’s offen!
Liebe Grüße, Otto
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 147
All Time: 4,553
