Up to 20% off select tools
BUSY Bar Disassembly
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
28
Past 30 Days:
143
All Time:
1,227
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
BUSY Bar is a customizable productivity and attention-management device featuring a large main display (LED, 72×16), a small monochrome rear display (OLED, 160×80), and physical controls. It integrates with mobile and desktop apps, supports third-party services, and has an open HTTP API.
The device supports Wi-Fi 6, Bluetooth Low Energy, and USB Virtual LAN. It also integrates with smart-home systems via Matter and runs on battery for fully autonomous use.
    1. BUSY Bar Disassembly, Remove the back cover: step 1, image 1 of 3 BUSY Bar Disassembly, Remove the back cover: step 1, image 2 of 3 BUSY Bar Disassembly, Remove the back cover: step 1, image 3 of 3
      • The back cover is held in place by 8 clips.
      • Use a plastic card to release one of the clips near the center at the bottom of the back cover.
      • Gently release the remaining clips until the back cover comes off completely.
      Ask FixBot
    2. BUSY Bar Disassembly, Remove the screws: step 2, image 1 of 3 BUSY Bar Disassembly, Remove the screws: step 2, image 2 of 3 BUSY Bar Disassembly, Remove the screws: step 2, image 3 of 3
      • Use a PH1 Phillips screwdriver to remove 1 screw from the bottom and 4 screws from the back of the device.
      Ask FixBot
    3. BUSY Bar Disassembly, Pull out the front display unit: step 3, image 1 of 3 BUSY Bar Disassembly, Pull out the front display unit: step 3, image 2 of 3 BUSY Bar Disassembly, Pull out the front display unit: step 3, image 3 of 3
      • Do not pull the display unit too far out of the housing, as this may damage the display cable or connectors.
      • Do not disconnect the display cable. The battery must be disconnected first.
      • Use a plastic card to release the 2 latches on top of the front display.
      • Gently pull the front display unit out toward the right.
      Ask FixBot
    4. BUSY Bar Disassembly, Remove the battery: step 4, image 1 of 3 BUSY Bar Disassembly, Remove the battery: step 4, image 2 of 3 BUSY Bar Disassembly, Remove the battery: step 4, image 3 of 3
      • Gently move the battery to the left so you can access the connector.
      • Use tweezers or your fingertip to press the connector latch.
      • Pull the battery connector to disconnect it from the PCB.
      Ask FixBot
    5. BUSY Bar Disassembly, Remove the front display unit: step 5, image 1 of 3 BUSY Bar Disassembly, Remove the front display unit: step 5, image 2 of 3 BUSY Bar Disassembly, Remove the front display unit: step 5, image 3 of 3
      • Use a spudger to release the display cable connector latch.
      • Pull the cable in the direction indicated by the arrow.
      • Remove the front display unit.
      Ask FixBot
    6. BUSY Bar Disassembly, Remove the battery pad: step 6, image 1 of 2 BUSY Bar Disassembly, Remove the battery pad: step 6, image 2 of 2
      • Use your fingers to lift and remove the silicone battery pad.
      Ask FixBot
    7. BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: step 7, image 1 of 3 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: step 7, image 2 of 3 BUSY Bar Disassembly, Disconnect the cable connecting the main and control PCBs: step 7, image 3 of 3
      • Use tweezers to remove the yellow tape from the connector on the main PCB.
      • Use a halberd spudger to release the connector latch.
      • Use tweezers to disconnect the cable from the connector.
      Ask FixBot
    8. BUSY Bar Disassembly, Disconnect the back display: step 8, image 1 of 2 BUSY Bar Disassembly, Disconnect the back display: step 8, image 2 of 2
      • Use a halberd spudger to release the latch on the display connector.
      • Gently press the flex cable with your finger and slide it out of the connector.
      Ask FixBot
    9. BUSY Bar Disassembly, Remove the speaker: step 9, image 1 of 3 BUSY Bar Disassembly, Remove the speaker: step 9, image 2 of 3 BUSY Bar Disassembly, Remove the speaker: step 9, image 3 of 3
      • Use a spudger to pry up the speaker connector and disconnect it.
      • Use tweezers to remove the speaker from the device housing.
      Ask FixBot
    10. BUSY Bar Disassembly, Remove the control knobs: step 10, image 1 of 3 BUSY Bar Disassembly, Remove the control knobs: step 10, image 2 of 3 BUSY Bar Disassembly, Remove the control knobs: step 10, image 3 of 3
      • Use a spudger or an opening tool to remove the scroll wheel, holding it with your other hand to prevent bending.
      • Using both hands, lift up the Start/Pause button knob to remove it.
      • Use a spudger or an opening tool to remove the mode selector cover.
      Ask FixBot
    11. BUSY Bar Disassembly, Remove the main PCB: step 11, image 1 of 3 BUSY Bar Disassembly, Remove the main PCB: step 11, image 2 of 3 BUSY Bar Disassembly, Remove the main PCB: step 11, image 3 of 3
      • Use a PH1 screwdriver to remove the 3 screws securing the PCB.
      • Carefully lift the PCB out of the device housing.
      Ask FixBot
    12. BUSY Bar Disassembly, Remove the control unit: step 12, image 1 of 3 BUSY Bar Disassembly, Remove the control unit: step 12, image 2 of 3 BUSY Bar Disassembly, Remove the control unit: step 12, image 3 of 3
      • Peel off the 2 black stickers from the control unit.
      • Use a spudger to release the 2 clips on the sides of the unit.
      • Use a halberd spudger to release the 2 clips closer to the center.
      • Remove the control unit from the device housing.
      Ask FixBot
    13. BUSY Bar Disassembly, Remove the Back button cap and the light guides: step 13, image 1 of 3 BUSY Bar Disassembly, Remove the Back button cap and the light guides: step 13, image 2 of 3 BUSY Bar Disassembly, Remove the Back button cap and the light guides: step 13, image 3 of 3
      • Remove the 2 white status indicator light guides by lifting them from the edge with your finger.
      • Use a spudger to release the latch securing the Back button cover.
      • Remove the Back button cover.
      Ask FixBot
    14. BUSY Bar Disassembly, Remove the button stabilizer: step 14, image 1 of 3 BUSY Bar Disassembly, Remove the button stabilizer: step 14, image 2 of 3 BUSY Bar Disassembly, Remove the button stabilizer: step 14, image 3 of 3
      • Remove the 3 screws from the bottom of the control unit.
      • Remove the stabilizer holder.
      Ask FixBot
    15. BUSY Bar Disassembly, Remove the control PCB from the housing: step 15, image 1 of 3 BUSY Bar Disassembly, Remove the control PCB from the housing: step 15, image 2 of 3 BUSY Bar Disassembly, Remove the control PCB from the housing: step 15, image 3 of 3
      • The control PCB is secured in the plastic housing by 5 latches.
      • Gently pull the PCB away from the plastic housing. You can pull by the scroll wheel or the mode selector.
      • Release the latches by bending them outward from the PCB using your finger, a spudger, or an opening tool.
      • Once all latches are released, remove the PCB from the housing.
      Ask FixBot
    16. BUSY Bar Disassembly, Disconnect the cable from the control PCB: step 16, image 1 of 2 BUSY Bar Disassembly, Disconnect the cable from the control PCB: step 16, image 2 of 2
      • Use a spudger to carefully release the connector latch.
      • Remove the flex cable.
      Ask FixBot
    17. BUSY Bar Disassembly, Remove the front display back cover: step 17, image 1 of 3 BUSY Bar Disassembly, Remove the front display back cover: step 17, image 2 of 3 BUSY Bar Disassembly, Remove the front display back cover: step 17, image 3 of 3
      • The back cover of the front display unit is secured by 6 latches.
      • Use a spudger or a plastic card to carefully release the latches around the front display.
      • Remove the back cover of the front display unit.
      Ask FixBot
    18. BUSY Bar Disassembly, Disassemble the front display unit: step 18, image 1 of 3 BUSY Bar Disassembly, Disassemble the front display unit: step 18, image 2 of 3 BUSY Bar Disassembly, Disassemble the front display unit: step 18, image 3 of 3
      • The front display unit consists of a display PCB with LEDs and LED drivers, a plastic light separator, a matte light-diffusing film, and an outer tinted glass.
      • Remove the display PCB from the front display unit.
      • Remove the light separator.
      • Remove the light-diffusing film.
      Ask FixBot
    19. BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: step 19, image 1 of 3 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: step 19, image 2 of 3 BUSY Bar Disassembly, Remove the light guide and the cable from the display PCB: step 19, image 3 of 3
      • Tilt the ambient light sensor light guide forward to disconnect it from the display PCB.
      • Use a spudger to release the flex cable connector latch.
      • Pull the flex cable in the direction indicated by the arrow to remove it.
      Ask FixBot
    20. BUSY Bar Disassembly, Remove the monitor mount: step 20, image 1 of 3 BUSY Bar Disassembly, Remove the monitor mount: step 20, image 2 of 3 BUSY Bar Disassembly, Remove the monitor mount: step 20, image 3 of 3
      • The 2 black polyurethane friction elements on the mount’s pivot create rotational resistance to hold the leg in intermediate positions.
      • Use a spudger to slide the 2 friction elements toward the center of the device. They move together with the short metal shafts and can then be removed from the housing.
      • Press the mount leg downward toward the center of the device (following the orange arrow).
      • At the same time push the mount leg sideways (following the red arrow) to release it from the slot.
      • Repeat these steps for the opposite side of the leg to remove it.
      Ask FixBot
    21. BUSY Bar Disassembly, Device fully disassembled: step 21, image 1 of 1
      • The device is now fully disassembled. The picture shows all its components.
      Ask FixBot
To reassemble the device, follow these steps in reverse order.
3 other people completed this guide.
Author
with
Flipper Devices
1,108 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 143
All Time: 1,227
