BRAUN Cruzer 5 - Battery Replacement
    1. BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: step 1, image 1 of 3 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: step 1, image 2 of 3 BRAUN Cruzer 5 - Battery Replacement, Trimmer Head removal: step 1, image 3 of 3
      • Remove the trimmer head.
      • Remove the two Torx T5 screws attaching the cover to the hand-piece.
      • Remove the cover.
      • Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
      Ask FixBot
    2. BRAUN Cruzer 5 - Battery Replacement, Back cover removal: step 2, image 1 of 3 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: step 2, image 2 of 3 BRAUN Cruzer 5 - Battery Replacement, Back cover removal: step 2, image 3 of 3
      • Remove the back cover.
      • Using a flat head screw driver, remove the single screw holding the power board in place.
      • Use compressed air to clean the motor. Lubricate the trimmer with a suitable lubricant.
      • Remove the two AAA batteries by de-soldering them with a soldering iron and de-soldering pump.
      • Bend the terminals of the new batteries and solder them back in the right direction
      • If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
      • Insert the board again, with the side towards the motor first
      Ask FixBot
    3. BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: step 3, image 1 of 3 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: step 3, image 2 of 3 BRAUN Cruzer 5 - Battery Replacement, Front Cover removal: step 3, image 3 of 3
      • Remove the front cover of the device.
      • Clean and lubricate this area thoroughly as well, then your device will run better.
      Ask FixBot
26 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Zweikeks
617 Reputation
2 Guides authored
7 Guide Comments
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
King Arthur - Reply Share
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Jaden Fox - Reply Share
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
Wilhelm Gregorius - Reply Share
I think one pcc— 1.2 V 1800 mah AA battary
Ünsal Şeker - Reply Share
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
Pedro Faria - Reply Share
Past 24 Hours: 9
Past 7 Days: 58
Past 30 Days: 233
All Time: 35,908
