BOSE SoundTouch 30 Power Supply Replacement
  1. BOSE SoundTouch 30 Power Supply Replacement, Base Plate: step 1, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement, Base Plate: step 1, image 2 of 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
    Ask FixBot
  2. BOSE SoundTouch 30 Power Supply Replacement, Power Supply: step 2, image 1 of 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
    Ask FixBot
  3. BOSE SoundTouch 30 Power Supply Replacement: step 3, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement: step 3, image 2 of 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
    Ask FixBot
  4. BOSE SoundTouch 30 Power Supply Replacement: step 4, image 1 of 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
    Ask FixBot
  5. BOSE SoundTouch 30 Power Supply Replacement: step 5, image 1 of 2 BOSE SoundTouch 30 Power Supply Replacement: step 5, image 2 of 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
    Ask FixBot
13 other people completed this guide.
Brennen Irey
1,269 Reputation
6 Guides authored
Cal Poly, Team S16-G2, Livingston Spring 2018 Member of Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Members
8 Guides authored
31 Guide Comments
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hitesh Gohill - Reply Share
Hello. Do you want to exchange power supplies?
Contact me please!
Tomás Rosales - Reply Share
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Josley Oliveira - Reply Share
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro - Reply Share
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 165
All Time: 14,279
