BOSE SoundTouch 30 Motherboard Replacement
    1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: step 1, image 1 of 2 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: step 1, image 2 of 2
      • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
      Ask FixBot
    1. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: step 2, image 1 of 1
      • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
      Ask FixBot
    2. BOSE SoundTouch 30 Motherboard Replacement: step 3, image 1 of 2 BOSE SoundTouch 30 Motherboard Replacement: step 3, image 2 of 2
      • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
      • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
      Ask FixBot
    3. BOSE SoundTouch 30 Motherboard Replacement: step 4, image 1 of 1
      • Remove all four 15.5 mm PH2 screws holding the power supply down.
      • The power supply is identified by a green board with a large metal covering.
      Ask FixBot
    4. BOSE SoundTouch 30 Motherboard Replacement: step 5, image 1 of 2 BOSE SoundTouch 30 Motherboard Replacement: step 5, image 2 of 2
      • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
      • Pick up the power supply and remove the fourth cable from the underside of the power supply.
      • Remove the power supply.
      Ask FixBot
    1. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: step 6, image 1 of 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: step 6, image 2 of 3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Remove the five 15.5 mm PH2 screws holding the motherboard down.
      • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
      • Remove the motherboard.
      • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
      Ask FixBot
5 other people completed this guide.
Brennen Irey
1,269 Reputation
6 Guides authored
Cal Poly, Team S16-G2, Livingston Spring 2018 Member of Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Members
72 Guides authored
5 Guide Comments
Where do I can get the power supply?
Ulises Peña - Reply Share
where can i get the notherboard? 354437-0060
guillermo gibson - Reply Share
Please where can I get the motherboard
Marjorie Newell - Reply Share
Where can I get the motherboard?
Bryan Lozano - Reply Share
I am getting an error “Error code 0000. Contact Bose service” what do I do?
Ashley Murray - Reply Share
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 92
All Time: 7,756
