Up to 20% off select tools
BOSE SoundTouch 30 Display Assembly Replacement
Views: 6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
37
Past 30 Days:
157
All Time:
5,993
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The display should be replaced in the event that it gets damaged beyond reasonable repair. Removing the display requires some caution due to the fragile nature of the ribbon connector.
    1. BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: step 1, image 1 of 2 BOSE SoundTouch 30 Display Assembly Replacement, Base Plate: step 1, image 2 of 2
      • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
      Ask FixBot
    1. BOSE SoundTouch 30 Display Assembly Replacement, Display Assembly: step 2, image 1 of 1
      • Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
      Ask FixBot
    2. BOSE SoundTouch 30 Display Assembly Replacement: step 3, image 1 of 1
      • Remove the grille by gripping the edges and pulling upwards.
      • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
      Ask FixBot
    3. BOSE SoundTouch 30 Display Assembly Replacement: step 4, image 1 of 2 BOSE SoundTouch 30 Display Assembly Replacement: step 4, image 2 of 2
      • Remove the six 8.9mm T9 torx screws holding the display assembly down.
      • The display assembly can now be lifted out of the grille so that a new one can be put in.
      Ask FixBot
4 other people completed this guide.
Author
with
Brennen Irey
1,269 Reputation
6 Guides authored
Cal Poly, Team S16-G2, Livingston Spring 2018 Member of Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 Members
72 Guides authored
1 Guide Comment
Display assembly price
imrankhannnnn786 - Reply Share
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 157
All Time: 5,993
