This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
BOSCH MUM7000 replace torn belt
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
78
All Time:
995
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
The motor in the machine starts, but nothing moves? The belt is probably torn, which you can get for a lot of money from BOSCH or, if you know what to look for, from other dealers directly.
Here are the instructions for replacing the belts.
Parts
    1. BOSCH MUM7000 replace torn belt, Open the housing: step 1, image 1 of 2 BOSCH MUM7000 replace torn belt, Open the housing: step 1, image 2 of 2
      • Remove the four Phillips screws.
      • Loosen some plastic latches
      • Simply "pull off" the knob while or before opening the housing.
      Ask FixBot
    2. BOSCH MUM7000 replace torn belt, divorce: step 2, image 1 of 2 BOSCH MUM7000 replace torn belt, divorce: step 2, image 2 of 2
      • Loosen the screw.
      • Turn back the plastic-tensioner so that the transmission separates from the rest.
      Ask FixBot
    3. BOSCH MUM7000 replace torn belt, Loosen belt: step 3, image 1 of 2 BOSCH MUM7000 replace torn belt, Loosen belt: step 3, image 2 of 2
      • Pull the black cap off the axle.
      • Flip the longer belt over the pulley.
      • Unscrew the three screws from the plastic cover.
      Ask FixBot
    4. BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 1 of 3 BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 2 of 3 BOSCH MUM7000 replace torn belt, Remove belt: step 4, image 3 of 3
      • Lever out the clamps. Remove the axle and take out the belts.
      • Remove the clutch / transmission.
      Ask FixBot
    5. BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 1 of 3 BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 2 of 3 BOSCH MUM7000 replace torn belt, Insert new belts: step 5, image 3 of 3
      • Insert the new belt with the axle.
      • Tension the 3M belts and reassemble everything.
      • The rotation of the 5M belt determines the running direction! Do it as in the picture, so that this is correct.
      Ask FixBot
Work through the steps in reverse order to reassemble your unit.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Moritz Graf
277 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 78
All Time: 995
