BMW X3 E83 Key Battery replacement
    • Try and see first if the key was simply "forgotten" by the car by reprogramming it:
    • Open the car with the second key, get in and close the door, but don't shut it all the way.
    • Put the key that needs to be reprogrammed into the starter and turn it to the "Radio" position. Leave it in this position for a few seconds and then pull it back out. The system is now ready for reprograming.
    • Press and hold-down the "open" button and then press the "close" button three times. Now, let go of the "open" button. The locking system should respond by locking and unlocking all doors, with a "click-clack"
    • Important: The second key must be reprogrammed within 10 seconds, otherwise it will no longer work. For this it must not be put back into the starter.
    • If this worked, you can stop - otherwise, follow the next steps.
    Ask FixBot
  1. BMW X3 E83 Key Battery replacement: step 2, image 1 of 3 BMW X3 E83 Key Battery replacement: step 2, image 2 of 3 BMW X3 E83 Key Battery replacement: step 2, image 3 of 3
    • The two halves of the casing are glued together. Separate the seam between the upper and lower casing with a sharp utility knife.
    • The process is tricky and time-consuming, cutting again and again around the key. Work slowly and patiently.
    • Don't cut deeper than 3 millimeters, so you don't come into contact with the circuit board.
    Ask FixBot
  2. BMW X3 E83 Key Battery replacement: step 3, image 1 of 3 BMW X3 E83 Key Battery replacement: step 3, image 2 of 3 BMW X3 E83 Key Battery replacement: step 3, image 3 of 3
    • When the seam is open wide enough, slide a pick inside.
    • Then separate the casings with an appropriate tool.
    Ask FixBot
  3. BMW X3 E83 Key Battery replacement: step 4, image 1 of 2 BMW X3 E83 Key Battery replacement: step 4, image 2 of 2
    • Here is what the inside of the casing looks like. The circuit board has already been removed.
    Ask FixBot
  4. BMW X3 E83 Key Battery replacement: step 5, image 1 of 3 BMW X3 E83 Key Battery replacement: step 5, image 2 of 3 BMW X3 E83 Key Battery replacement: step 5, image 3 of 3
    • The circuit board.
    • The battery type is VL2020. Pay attention to the welded flag connectors, which are in right angles of each other.
    Ask FixBot
  5. BMW X3 E83 Key Battery replacement: step 6, image 1 of 3 BMW X3 E83 Key Battery replacement: step 6, image 2 of 3 BMW X3 E83 Key Battery replacement: step 6, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Desolder the battery from the solder pads marked in red.
    • Use a desoldering pump or desoldering wick.
    • Lift the battery out carefully.
    Ask FixBot
  6. BMW X3 E83 Key Battery replacement: step 7, image 1 of 2 BMW X3 E83 Key Battery replacement: step 7, image 2 of 2
    • If there isn't an insulation layer on the back, then place a piece of insulation tape there.
    Ask FixBot
  7. BMW X3 E83 Key Battery replacement: step 8, image 1 of 1
    • Put everything back together. Do not glue the casings yet. Instead, hold them together with a rubber band.
    • Check whether the micro switches are clicking. If not, move the circuit board back into the right position again.
    • Normally, the key - as mentioned in step 1 - will have to be reprogrammed. And don’t forget about the second key.
    • When everything is working, you can glue the two halves back together with the appropriate glue – for instance Super Glue – and carefully sand off any excess glue.
    Ask FixBot
Complete the steps in reverse order to reassemble your device.
6 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
335,299 Reputation
311 Guides authored
3 Guide Comments
How much BMW X3 2008 model fuel pump??
ferobe2000 - Reply Share
I need help I have a 2004 BMW X3 I was idling in the driveway and it just died like it ran out of gas well I checked the fuel pump and I wasn't getting any power back to the fuel pump so I jumped the relay now I'm getting power back to the fuel pump but the car still doesn't start I've checked all the fuses replace the relays I'm wondering if it's my key not synced up with a car somehow or if something else is wrong if anybody knows please help me
Andrew Duggar - Reply Share
Same thing happen to my bmwx3 my battery to the car was not good I bought a new one and now my car won't start everything goes on the dashb9ard but won't start do i have to program the key and how to do it
Maricela - Reply Share
Past 24 Hours: 29
Past 7 Days: 154
Past 30 Days: 736
All Time: 47,549
