BLU Vivo 5 Mini Camera Replacement
    1. BLU Vivo 5 Mini Camera Replacement, Back Cover: step 1, image 1 of 3 BLU Vivo 5 Mini Camera Replacement, Back Cover: step 1, image 2 of 3 BLU Vivo 5 Mini Camera Replacement, Back Cover: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
      • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
      Ask FixBot
    2. BLU Vivo 5 Mini Camera Replacement: step 2, image 1 of 3 BLU Vivo 5 Mini Camera Replacement: step 2, image 2 of 3 BLU Vivo 5 Mini Camera Replacement: step 2, image 3 of 3
      • Remove the top and bottom covers.
      • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
      • After freeing the edges gentle start peeling the covers off.
      Ask FixBot
    3. BLU Vivo 5 Mini Camera Replacement: step 3, image 1 of 3 BLU Vivo 5 Mini Camera Replacement: step 3, image 2 of 3 BLU Vivo 5 Mini Camera Replacement: step 3, image 3 of 3
      • Using a Phillips #000, remove all 10 screws found on the back of the phone.
      • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
      • The 4 on the top can be removed with the same screwdriver.
      Ask FixBot
    4. BLU Vivo 5 Mini Camera Replacement: step 4, image 1 of 3 BLU Vivo 5 Mini Camera Replacement: step 4, image 2 of 3 BLU Vivo 5 Mini Camera Replacement: step 4, image 3 of 3
      • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
      • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
      • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
      Ask FixBot
    1. BLU Vivo 5 Mini Camera Replacement, Camera: step 5, image 1 of 1
      Buy
      • Using tweezers, remove the top black encasing of the camera.
      Ask FixBot
    2. BLU Vivo 5 Mini Camera Replacement: step 6, image 1 of 3 BLU Vivo 5 Mini Camera Replacement: step 6, image 2 of 3 BLU Vivo 5 Mini Camera Replacement: step 6, image 3 of 3
      • Using the tweezers unlink the camera gently from the gold wire
      Ask FixBot
    3. BLU Vivo 5 Mini Camera Replacement: step 7, image 1 of 2 BLU Vivo 5 Mini Camera Replacement: step 7, image 2 of 2
      • Gently lift the back camera from the phone.
      • Be careful not to smudge the lens. At this time, also check for debris.
      Ask FixBot
    4. BLU Vivo 5 Mini Camera Replacement: step 8, image 1 of 3 BLU Vivo 5 Mini Camera Replacement: step 8, image 2 of 3 BLU Vivo 5 Mini Camera Replacement: step 8, image 3 of 3
      • Use the spudger to gently lift the motherboard out of the device.
      • After completely removing the back camera and motherboard, now check underneath for debris near front lens.
      • Front lens can now be removed for replacement.
      Ask FixBot
Kymari
725 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 54
All Time: 556
