Up to 20% off select tools
BLU Tank II Outer Lens Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
75
All Time:
614
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will detail how to remove and replace the outer lens of the camera of the BLU Tank II cell phone. The guide will require knowledge from the previous guides in order to successfully replace the lens. This guide requires a screwdriver and an opening tool.
    1. BLU Tank II Outer Lens Replacement, Back Panel: step 1, image 1 of 2 BLU Tank II Outer Lens Replacement, Back Panel: step 1, image 2 of 2
      • With the screen facing you, find the left corner of the phone. There should be a visible groove.
      • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
      Ask FixBot
    1. BLU Tank II Outer Lens Replacement, Battery: step 2, image 1 of 1
      • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
      • Lift the battery up and carefully remove the battery.
      Ask FixBot
    1. BLU Tank II Outer Lens Replacement, Front Panel: step 3, image 1 of 2 BLU Tank II Outer Lens Replacement, Front Panel: step 3, image 2 of 2
      • Using the phillips head screwdriver, remove all 5 2.5mm screws.
      Ask FixBot
    2. BLU Tank II Outer Lens Replacement: step 4, image 1 of 1
      • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
      • Carefully separate the front plate from all sides of the phone.
      Ask FixBot
    1. BLU Tank II Outer Lens Replacement, Motherboard: step 5, image 1 of 2 BLU Tank II Outer Lens Replacement, Motherboard: step 5, image 2 of 2
      • Locate the two 2.5mm screws (red circles in image) and remove them with the Philips 00 screwdriver used previously.
      Ask FixBot
    2. BLU Tank II Outer Lens Replacement: step 6, image 1 of 3 BLU Tank II Outer Lens Replacement: step 6, image 2 of 3 BLU Tank II Outer Lens Replacement: step 6, image 3 of 3
      • Once screws are removed, separate the motherboard and outer lens by carefully pushing the motherboard out with your hand as displayed in the image.
      Ask FixBot
    1. BLU Tank II Outer Lens Replacement, Outer Lens: step 7, image 1 of 2 BLU Tank II Outer Lens Replacement, Outer Lens: step 7, image 2 of 2
      • Once separated from the motherboard, the outer lens can now be replaced.
      Ask FixBot
Author
with
David Kelchner
632 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 75
All Time: 614
