Up to 20% off select tools
BLU Tank II Front Panel Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
83
All Time:
746
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate the steps needed to remove and replace the front panel for the BLU Tank II. Removing the back panel is a step required to replace the outer screen and change color/customization of phone
    1. BLU Tank II Front Panel Replacement, Back Panel: step 1, image 1 of 2 BLU Tank II Front Panel Replacement, Back Panel: step 1, image 2 of 2
      • With the screen facing you, find the left corner of the phone. There should be a visible groove.
      • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
      Ask FixBot
    1. BLU Tank II Front Panel Replacement, Battery: step 2, image 1 of 1
      • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
      • Lift the battery up and carefully remove the battery.
      Ask FixBot
    1. BLU Tank II Front Panel Replacement, Front Panel: step 3, image 1 of 2 BLU Tank II Front Panel Replacement, Front Panel: step 3, image 2 of 2
      • Using the phillips head screwdriver, remove all 5 2.5mm screws.
      Ask FixBot
    2. BLU Tank II Front Panel Replacement: step 4, image 1 of 1
      • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
      • Carefully separate the front plate from all sides of the phone.
      Ask FixBot
Author
with
David Kelchner
632 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 83
All Time: 746
