Up to 20% off select tools
BLU Studio G Screen Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
66
All Time:
2,745
Comments: 5
5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Use this guide to fix a broken or cracked screen on the BLU Studio G. The replacement will require a near complete disassembly of the phone since the connections to the motherboard will have to be disengaged.
    1. Careful: steps 1-8 are sourced from a guide that's marked as in-progress.
      BLU Studio G Screen Replacement, Motherboard Prerequisite: step 1, image 1 of 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: step 1, image 2 of 3 BLU Studio G Screen Replacement, Motherboard Prerequisite: step 1, image 3 of 3
      • To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
      • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
      Ask FixBot
    2. BLU Studio G Screen Replacement: step 2, image 1 of 2 BLU Studio G Screen Replacement: step 2, image 2 of 2
      • Locate the notch at the bottom of the battery for safe removal.
      • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
      Ask FixBot
    3. BLU Studio G Screen Replacement: step 3, image 1 of 2 BLU Studio G Screen Replacement: step 3, image 2 of 2
      • Unscrew the 13 Phillips #0 screws from the back of the phone.
      Ask FixBot
    4. BLU Studio G Screen Replacement: step 4, image 1 of 1
      • To remove the back panel, slide the metal spudger into 3 notches on left and right side outside edges of the device.
      • With some slow but strong pressure insert and dislodge the panel from the rest of the device. These are tough but small clips that hold together the back panel.
      Ask FixBot
    5. BLU Studio G Screen Replacement: step 5, image 1 of 2 BLU Studio G Screen Replacement: step 5, image 2 of 2
      • Remove all 8 3.175 mm screws that secure the motherboard in place.
      • Remove by turning counter clockwise using a Phillips #0 bit with the correct screwdriver using medium/ firm pressure, assuring that you don't strip the screws.
      • Set aside
      Ask FixBot
    6. BLU Studio G Screen Replacement: step 6, image 1 of 3 BLU Studio G Screen Replacement: step 6, image 2 of 3 BLU Studio G Screen Replacement: step 6, image 3 of 3
      • Locate the two connector clamps on the motherboard.
      • Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
      • Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
      Ask FixBot
    7. BLU Studio G Screen Replacement: step 7, image 1 of 1
      • Locate the speaker on the bottom of the device and slowly pry upwards and to the right as its wired to the motherboard.
      Ask FixBot
    8. BLU Studio G Screen Replacement: step 8, image 1 of 3 BLU Studio G Screen Replacement: step 8, image 2 of 3 BLU Studio G Screen Replacement: step 8, image 3 of 3
      • Locate the volume button strip on the left side of the device and slowly pry outwards from one end to the other from the device.
      • Carefully pull over the motherboard.
      Ask FixBot
    1. BLU Studio G Screen Replacement, Screen: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Turn the phone over after detaching the connectors that were attached to the motherboard
      • Carefully pry between the screen and the bevel with precision tweezers lifting slowly separating the screen.
      • Use of another thin tool will help support the lifting
      Ask FixBot
    2. BLU Studio G Screen Replacement: step 10, image 1 of 3 BLU Studio G Screen Replacement: step 10, image 2 of 3 BLU Studio G Screen Replacement: step 10, image 3 of 3
      • Insert the metal spudger between the screen and the frame, using the blue plastic tool as a brace to prevent the screen from reattaching to the frame.
      • To fully remove the screen from the frame, repeat the previous step around the entire perimeter of the device.
      • Carefully remove the screen.
      Ask FixBot
4 other people completed this guide.
Author
with
Christian Perez
542 Reputation
4 Guides authored
5 Guide Comments
Thank YOU and I will begin disassembling my BLU as soon as I receive a phone screen. that is entirely different but resembles my BLU enough to use these steps to complete the mission.
Lamiah - Reply Share
Can anyone tell me where I can buy a screen for a blu view 3
Thank you
mrcblake50@gmail.com
Charles Blake (Mr Blake) - Reply Share
Most thorough and informative procedure out of the many I reviewed. Thank you.
Alan Doud - Reply Share
I need screen fue the sam3 ministerio blu.where to buy
Alexis urdaneta - Reply Share
Hi
I need digitizer where can I get one
Pls reply
Thanks
BiD N Buy - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 66
All Time: 2,745
