BLU Studio 5.0 II Back Case Replacement
  1. BLU Studio 5.0 II Back Case Replacement, Battery: step 1, image 1 of 1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Back Case Replacement: step 2, image 1 of 2 BLU Studio 5.0 II Back Case Replacement: step 2, image 2 of 2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Back Case Replacement: step 3, image 1 of 3 BLU Studio 5.0 II Back Case Replacement: step 3, image 2 of 3 BLU Studio 5.0 II Back Case Replacement: step 3, image 3 of 3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Back Case Replacement, Back Case: step 4, image 1 of 1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Back Case Replacement: step 5, image 1 of 3 BLU Studio 5.0 II Back Case Replacement: step 5, image 2 of 3 BLU Studio 5.0 II Back Case Replacement: step 5, image 3 of 3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
Ricardo Sarabia
1,069 Reputation
6 Guides authored
USF Tampa, Team 7-5, Cheng Spring 2016 Member of USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 582
