BLU R2 Plus Front-Facing Camera Replacement
    1. BLU R2 Plus Front-Facing Camera Replacement, Power Off: step 1, image 1 of 1
      • Be sure that your BLU R2 Plus is completely powered off and has less than 25% battery left. This will lower the chance of your battery catching fire and your logic board/motherboard shorting out.
      Ask FixBot
    2. BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: step 2, image 1 of 3 BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: step 2, image 2 of 3 BLU R2 Plus Front-Facing Camera Replacement, Releasing the Back Cover: step 2, image 3 of 3
      • Insert your pick in the top left-hand corner where the little indent is.
      • Slide the pick all the way around the phone until the back cover is loose and ready to be released.
      Ask FixBot
    3. BLU R2 Plus Front-Facing Camera Replacement, Remove the Back Cover: step 3, image 1 of 1
      • Remove the back cover and set it aside.
      Ask FixBot
    4. BLU R2 Plus Front-Facing Camera Replacement, Reveal the Screws: step 4, image 1 of 2 BLU R2 Plus Front-Facing Camera Replacement, Reveal the Screws: step 4, image 2 of 2
      • On both sides of the battery, use an opening pick to peel up the edge of the sticker covering the battery shield in order to expose the screws securing the plastic plating.
      Ask FixBot
    5. BLU R2 Plus Front-Facing Camera Replacement, Tape the sticker: step 5, image 1 of 1
      • Use tape to hold back the battery sticker so it's easier to unscrew the plates.
      Ask FixBot
    6. BLU R2 Plus Front-Facing Camera Replacement, Unscrew Upper Plastic Plate: step 6, image 1 of 2 BLU R2 Plus Front-Facing Camera Replacement, Unscrew Upper Plastic Plate: step 6, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Phillips #00 screwdriver to remove the 9 screws from the upper plastic plate.
      • Use a magnetic mat to organize your screws and prevent you from losing them.
      Ask FixBot
    7. BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: step 7, image 1 of 3 BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: step 7, image 2 of 3 BLU R2 Plus Front-Facing Camera Replacement, Upper Plate Removal: step 7, image 3 of 3
      • Use an opening pick to unclip the upper plastic plate from the phone.
      • Once unclipped, slide it up and out of the phone.
      • Be careful not to break the small arms of the plate upon removal.
      Ask FixBot
    8. BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: step 8, image 1 of 3 BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: step 8, image 2 of 3 BLU R2 Plus Front-Facing Camera Replacement, Front-Facing Camera Removal: step 8, image 3 of 3
      Buy
      • Use a spudger to unclip the ribbon cable from the motherboard/logic board. Carefully use blunt tweezers or angled tweezers to pull the ribbon cable out of the socket. Then use the tweezers to wiggle the camera out of its socket.
      • Be very careful not to break the ribbon cable as it's very fragile. This doesn't really matter if you're taking the camera out as it's already broken.
      Ask FixBot
Derek Thomas
778 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 55
All Time: 290
