BLU Life XL Rear Camera Replacement
    1. BLU Life XL Rear Camera Replacement, Rear Camera: step 1, image 1 of 3 BLU Life XL Rear Camera Replacement, Rear Camera: step 1, image 2 of 3 BLU Life XL Rear Camera Replacement, Rear Camera: step 1, image 3 of 3
      • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
      • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
      • Remove the battery by lifting the lower edge of the battery up first.
      Ask FixBot
    2. BLU Life XL Rear Camera Replacement: step 2, image 1 of 2 BLU Life XL Rear Camera Replacement: step 2, image 2 of 2
      • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
      Ask FixBot
    3. BLU Life XL Rear Camera Replacement: step 3, image 1 of 2 BLU Life XL Rear Camera Replacement: step 3, image 2 of 2
      • Insert the plastic prying tool in between the plastic frame and the device.
      • Keep the phone on the surface with its screen down.
      Ask FixBot
    4. BLU Life XL Rear Camera Replacement: step 4, image 1 of 2 BLU Life XL Rear Camera Replacement: step 4, image 2 of 2
      • Use the plastic prying tool to gently push the rear camera out from its socket.
      • Take the camera out and set it aside.
      Ask FixBot
    5. BLU Life XL Rear Camera Replacement: step 5, image 1 of 2 BLU Life XL Rear Camera Replacement: step 5, image 2 of 2
      • Carefully place the new camera in the camera socket.
      • Apply a little force on the top of the camera to slide it in the socket.
      • Pop the camera in the socket and make sure its stable.
      Ask FixBot
Shantanu Malhotra
178 Reputation
1 Guide authored
USF Tampa, Team S2-G5, Eyestone Spring 2018 Member of USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 70
All Time: 653
