Up to 20% off select tools
BLU Life X8 Daughterboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
86
All Time:
876
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The daughterboard is connected to the bottom speaker, the USB port, and the touch screen, so if one of these isn't functioning properly the daughterboard may need to be replaced. This guide explains how to access, remove, and replace the daughterboard of your BLU Life X8.
    1. BLU Life X8 Daughterboard  Replacement, Battery: step 1, image 1 of 2 BLU Life X8 Daughterboard  Replacement, Battery: step 1, image 2 of 2
      • Flip the phone over so that the screen is facing down.
      • Slide the opening tool between the micro-USB port and the back cover.
      • Use the opening tool to create a gap.
      Ask FixBot
    2. BLU Life X8 Daughterboard  Replacement: step 2, image 1 of 1
      • Use your thumb to pry off the back panel once the gap is large enough.
      Ask FixBot
    3. BLU Life X8 Daughterboard  Replacement: step 3, image 1 of 1
      • Once the back panel is off, locate the indent at the bottom of the battery.
      • Use your thumb to slip the battery out of the case.
      Ask FixBot
    1. BLU Life X8 Daughterboard  Replacement, Motherboard: step 4, image 1 of 2 BLU Life X8 Daughterboard  Replacement, Motherboard: step 4, image 2 of 2
      • Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
      Ask FixBot
    2. BLU Life X8 Daughterboard  Replacement: step 5, image 1 of 1
      • Wedge the opening tool into the seam of between the screen and the gray frame.
      • Run the opening tool along the seam to release the clips that hold the two pieces together.
      • You may need to use the opening picks to prevent the clips from re-engaging.
      Ask FixBot
    3. BLU Life X8 Daughterboard  Replacement: step 6, image 1 of 1
      • Once all the clips have been released, lift the frame and set it aside.
      Ask FixBot
    4. BLU Life X8 Daughterboard  Replacement: step 7, image 1 of 2 BLU Life X8 Daughterboard  Replacement: step 7, image 2 of 2
      • Use the Phillips #00 Phillips bit to undo the two 1.5mm screws from the motherboard.
      Ask FixBot
    5. BLU Life X8 Daughterboard  Replacement: step 8, image 1 of 3 BLU Life X8 Daughterboard  Replacement: step 8, image 2 of 3 BLU Life X8 Daughterboard  Replacement: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Use the tweezers to peel away the mesh tape and reveal the ribbon connectors.
      • Use the tweezers to lift the brown and black tabs to release the ribbon cables and unlock them.
      Ask FixBot
    6. BLU Life X8 Daughterboard  Replacement: step 9, image 1 of 1
      • The ribbon cables should be free. Pull back on the ribbons to release them from their connectors.
      Ask FixBot
    7. BLU Life X8 Daughterboard  Replacement: step 10, image 1 of 1
      • Slowly lift the vibration motor away from the frame and peel up the tape.
      Ask FixBot
    1. BLU Life X8 Daughterboard  Replacement, Daughterboard: step 11, image 1 of 1
      • Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
      Ask FixBot
    2. BLU Life X8 Daughterboard  Replacement: step 12, image 1 of 1
      Buy
      • Remove the transparent tape covering one of the ribbon connectors using the tweezers.
      Ask FixBot
    3. BLU Life X8 Daughterboard  Replacement: step 13, image 1 of 3 BLU Life X8 Daughterboard  Replacement: step 13, image 2 of 3 BLU Life X8 Daughterboard  Replacement: step 13, image 3 of 3
      • Use the tweezers to lift the black and beige tabs securing the ribbon cables.
      • Pull back on the ribbon cables to release them from their connectors.
      Ask FixBot
    4. BLU Life X8 Daughterboard  Replacement: step 14, image 1 of 1
      • Lift the daughterboard from the frame using the plastic opening tool.
      Ask FixBot
Author
with
Nicholas Harmon
166 Reputation
1 Guide authored
USF Tampa, Team S1-G2, Nance Fall 2017 Member of USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 86
All Time: 876
