BLU Energy X USB Board Replacement
    1. BLU Energy X USB Board Replacement, Battery: step 1, image 1 of 3 BLU Energy X USB Board Replacement, Battery: step 1, image 2 of 3 BLU Energy X USB Board Replacement, Battery: step 1, image 3 of 3
      • Remove the back case using plastic opening tool.
      Ask FixBot
    2. BLU Energy X USB Board Replacement: step 2, image 1 of 2 BLU Energy X USB Board Replacement: step 2, image 2 of 2
      • Remove the seven 4mm Phillips #000 screws.
      • Remove the top plate.
      Ask FixBot
    3. BLU Energy X USB Board Replacement: step 3, image 1 of 3 BLU Energy X USB Board Replacement: step 3, image 2 of 3 BLU Energy X USB Board Replacement: step 3, image 3 of 3
      • Detach the battery from the mother board using a plastic opening tool.
      • Use a plastic spudger to remove battery.
      Ask FixBot
    1. BLU Energy X USB Board Replacement, USB Board: step 4, image 1 of 2 BLU Energy X USB Board Replacement, USB Board: step 4, image 2 of 2
      • Remove the five 4 mm JIS J000 screws from bottom plate
      • Remove the bottom casing.
      Ask FixBot
    2. BLU Energy X USB Board Replacement: step 5, image 1 of 2 BLU Energy X USB Board Replacement: step 5, image 2 of 2
      • Disconnect vibration motor and connector as indicated.
      • Remove motherboard.
      Ask FixBot
2 other people completed this guide.
Jeanine Sam
211 Reputation
1 Guide authored
USF Tampa, Team 12-2, Eyestone Spring 2016 Member of USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 98
All Time: 890
