BLU Energy X Plus Battery Replacement
    1. BLU Energy X Plus Battery Replacement, Battery: step 1, image 1 of 2 BLU Energy X Plus Battery Replacement, Battery: step 1, image 2 of 2
      • Before disassembling your BLU Energy X Plus, make sure it is powered off.
      • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
      Ask FixBot
    2. BLU Energy X Plus Battery Replacement: step 2, image 1 of 2 BLU Energy X Plus Battery Replacement: step 2, image 2 of 2
      • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
      Ask FixBot
    3. BLU Energy X Plus Battery Replacement: step 3, image 1 of 1
      • Flip your device over so your back cover is facing up.
      Ask FixBot
    4. BLU Energy X Plus Battery Replacement: step 4, image 1 of 2 BLU Energy X Plus Battery Replacement: step 4, image 2 of 2
      • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
      Ask FixBot
    5. BLU Energy X Plus Battery Replacement: step 5, image 1 of 2 BLU Energy X Plus Battery Replacement: step 5, image 2 of 2
      • Remove the six silver screws from the cover plate, and one black screw from the top.
      • Use the screwdriver head J000 to remove all the screws.
      • Six silver screws, all 1.5mm in length.
      • One black screw, 1mm in length.
      Ask FixBot
    6. BLU Energy X Plus Battery Replacement: step 6, image 1 of 1
      • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
      Ask FixBot
    7. BLU Energy X Plus Battery Replacement: step 7, image 1 of 1
      • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
      Ask FixBot
    8. BLU Energy X Plus Battery Replacement: step 8, image 1 of 2 BLU Energy X Plus Battery Replacement: step 8, image 2 of 2
      • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
      • Then, use your hand to remove the battery completely.
      Ask FixBot
5 other people completed this guide.
woodjake94
638 Reputation
5 Guides authored
USF Tampa, Team 2-121, Cagle Spring 2016 Member of USF Tampa, Team 2-121, Cagle Spring 2016
USFT-CAGLE-S16S2G121
4 Members
60 Guides authored
2 Guide Comments
what about a Blu Energy XL
Anthony Johnson - Reply Share
Muito obrigada!
Estava com um travamento no sistema que impedia reiniciar o smartphone.
Depois de desconectar a bateria e conectar novamente o celular voltou ao normal!
Nicoli - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 110
All Time: 6,868
