BLU Energy X Motherboard Replacement
    1. BLU Energy X Motherboard Replacement, Battery: step 1, image 1 of 3 BLU Energy X Motherboard Replacement, Battery: step 1, image 2 of 3 BLU Energy X Motherboard Replacement, Battery: step 1, image 3 of 3
      • Remove the back case using plastic opening tool.
      Ask FixBot
    2. BLU Energy X Motherboard Replacement: step 2, image 1 of 2 BLU Energy X Motherboard Replacement: step 2, image 2 of 2
      • Remove the seven 4mm Phillips #000 screws.
      • Remove the top plate.
      Ask FixBot
    3. BLU Energy X Motherboard Replacement: step 3, image 1 of 3 BLU Energy X Motherboard Replacement: step 3, image 2 of 3 BLU Energy X Motherboard Replacement: step 3, image 3 of 3
      • Detach the battery from the mother board using a plastic opening tool.
      • Use a plastic spudger to remove battery.
      Ask FixBot
    1. BLU Energy X Motherboard Replacement, Motherboard: step 4, image 1 of 2 BLU Energy X Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
      Ask FixBot
    2. BLU Energy X Motherboard Replacement: step 5, image 1 of 2 BLU Energy X Motherboard Replacement: step 5, image 2 of 2
      • Gently pull the ribbon cable free of the ZIF connector.
      Ask FixBot
    3. BLU Energy X Motherboard Replacement: step 6, image 1 of 2 BLU Energy X Motherboard Replacement: step 6, image 2 of 2
      • Gently peel up the antenna.
      • This is secured with some light adhesive, so some force may be required.
      Ask FixBot
    4. BLU Energy X Motherboard Replacement: step 7, image 1 of 3 BLU Energy X Motherboard Replacement: step 7, image 2 of 3 BLU Energy X Motherboard Replacement: step 7, image 3 of 3
      • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
      • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
      Ask FixBot
    5. BLU Energy X Motherboard Replacement: step 8, image 1 of 2 BLU Energy X Motherboard Replacement: step 8, image 2 of 2
      • Lift the motherboard up and out of the device.
      Ask FixBot
Geoff Wacker
93,075 Reputation
88 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 98
All Time: 784
