Up to 20% off select tools
BLU Energy X Battery Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
89
All Time:
2,735
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide the user will have to open the back of the phone and remove the top pate to expose the battery connection to the motherboard. Because the battery is not supposed to be removed, there is an adhesive on the back of the battery that makes it difficult to remove from the phone. The metal spudger is the best tool to use to pry the battery from the phone body.
    1. BLU Energy X Battery Replacement, Battery: step 1, image 1 of 3 BLU Energy X Battery Replacement, Battery: step 1, image 2 of 3 BLU Energy X Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the back case using plastic opening tool.
      Ask FixBot
    2. BLU Energy X Battery Replacement: step 2, image 1 of 2 BLU Energy X Battery Replacement: step 2, image 2 of 2
      • Remove the seven 4mm Phillips #000 screws.
      • Remove the top plate.
      Ask FixBot
    3. BLU Energy X Battery Replacement: step 3, image 1 of 3 BLU Energy X Battery Replacement: step 3, image 2 of 3 BLU Energy X Battery Replacement: step 3, image 3 of 3
      • Detach the battery from the mother board using a plastic opening tool.
      • Use a plastic spudger to remove battery.
      Ask FixBot
4 other people completed this guide.
Author
with
Sishun Wang
630 Reputation
4 Guides authored
USF Tampa, Team 12-2, Eyestone Spring 2016 Member of USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 Members
60 Guides authored
2 Guide Comments
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
tamara diale - Reply Share
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
joe doe (ch555x) - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 89
All Time: 2,735
