BLU Dash 3.5 Camera Replacement
  1. BLU Dash 3.5 Camera Replacement, Battery: step 1, image 1 of 3 BLU Dash 3.5 Camera Replacement, Battery: step 1, image 2 of 3 BLU Dash 3.5 Camera Replacement, Battery: step 1, image 3 of 3
    • Start by locating the slot on the lower right corner of the device.
    • Insert the opening tool into the slot.
    • Pry the back cover off. Once the corner is off, continue around the perimeter of the phone pulling the back off with your fingers.
    • A fingernail can work to open the back in place of an opening tool.
  2. BLU Dash 3.5 Camera Replacement: step 2, image 1 of 2 BLU Dash 3.5 Camera Replacement: step 2, image 2 of 2
    • Locate the indentation at the bottom of the battery.
    • Insert your thumb and pull the battery out.
  3. BLU Dash 3.5 Camera Replacement, Camera: step 3, image 1 of 3 BLU Dash 3.5 Camera Replacement, Camera: step 3, image 2 of 3 BLU Dash 3.5 Camera Replacement, Camera: step 3, image 3 of 3
    • Use the J000 Phillips screwdriver to remove the four 4.5 mm screws from the corners of the interior back panel.
    • Use the opening tool to pry open the plastic back panel to expose the motherboard.
  4. BLU Dash 3.5 Camera Replacement: step 4, image 1 of 2 BLU Dash 3.5 Camera Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Locate camera module on inside of the black plastic back panel
    • Note the orientation of the camera.
    • Use tweezers to carefully remove the camera.
victoria dorony
22 Reputation
1 Guide authored
Ohio State, Team 1-2, Garvin Fall 2015 Member of Ohio State, Team 1-2, Garvin Fall 2015
OSU-GARVIN-F15S1G2
4 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 485
