BLU Advance 4.0 Rear Case Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: step 1, image 1 of 2 BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: step 1, image 2 of 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: step 2, image 1 of 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: step 2, image 2 of 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: step 2, image 3 of 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Rear Case Disassembly, Separating motherboard from screen: step 3, image 1 of 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
David Okide
14 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 9
All Time: 8,553
