Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
BIOS battery replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
157
All Time:
2,211
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. BIOS battery replacement, Battery: step 1, image 1 of 3 BIOS battery replacement, Battery: step 1, image 2 of 3 BIOS battery replacement, Battery: step 1, image 3 of 3
      • Unlock the battery latch on the right.
      • Unlock the battery lock on the left.
      • Remove the battery pack from its slot.
      Ask FixBot
    1. BIOS battery replacement, Access to Components 1: step 2, image 1 of 3 BIOS battery replacement, Access to Components 1: step 2, image 2 of 3 BIOS battery replacement, Access to Components 1: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
      • Check the marks indicating the direction in which the cover must be removed.
      • Remove the bottom cover by removing it in the direction of the markers.
      Ask FixBot
    2. BIOS battery replacement: step 3, image 1 of 1
      • HDD hard disk and BIOS stack components appear.
      Ask FixBot
    1. BIOS battery replacement, BIOS battery: step 4, image 1 of 2 BIOS battery replacement, BIOS battery: step 4, image 2 of 2
      • Remove the battery connector first.
      • Then gently peel off the BIOS stack itself.
      Ask FixBot
For reassembly, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 157
All Time: 2,211
