BEM Mojo 2 Speaker Replacement
  1. BEM Mojo 2 Speaker Replacement, Speaker Battery: step 1, image 1 of 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
    Ask FixBot
  2. BEM Mojo 2 Speaker Replacement: step 2, image 1 of 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
    Ask FixBot
  3. BEM Mojo 2 Speaker Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
    Ask FixBot
  4. BEM Mojo 2 Speaker Replacement: step 4, image 1 of 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
    Ask FixBot
  5. BEM Mojo 2 Speaker Replacement: step 5, image 1 of 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
    Ask FixBot
  6. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: step 6, image 1 of 1
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
    Ask FixBot
  7. BEM Mojo 2 Speaker Replacement: step 7, image 1 of 1
    Buy
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
    Ask FixBot
  8. BEM Mojo 2 Speaker Replacement: step 8, image 1 of 1
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
    Ask FixBot
  9. BEM Mojo 2 Speaker Replacement, Speaker: step 9, image 1 of 1
    • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
    Ask FixBot
  10. BEM Mojo 2 Speaker Replacement: step 10, image 1 of 2 BEM Mojo 2 Speaker Replacement: step 10, image 2 of 2
    • Remove the speaker's four 10 mm base screws.
    Ask FixBot
  11. BEM Mojo 2 Speaker Replacement: step 11, image 1 of 2 BEM Mojo 2 Speaker Replacement: step 11, image 2 of 2
    • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
    • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
    Ask FixBot
  12. BEM Mojo 2 Speaker Replacement: step 12, image 1 of 2 BEM Mojo 2 Speaker Replacement: step 12, image 2 of 2
    • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
    Ask FixBot
Rachel Iacoboni
618 Reputation
5 Guides authored
Baylor, Team S1-G1, Johnson Spring 2018 Member of Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 34
All Time: 760
