BEM Mojo 2 Speaker Battery Replacement
  1. BEM Mojo 2 Speaker Battery Replacement, Speaker Battery: step 1, image 1 of 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
    Ask FixBot
  2. BEM Mojo 2 Speaker Battery Replacement: step 2, image 1 of 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
    Ask FixBot
  3. BEM Mojo 2 Speaker Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
    Ask FixBot
  4. BEM Mojo 2 Speaker Battery Replacement: step 4, image 1 of 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
    Ask FixBot
  5. BEM Mojo 2 Speaker Battery Replacement: step 5, image 1 of 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
    Ask FixBot
Rachel Iacoboni
618 Reputation
5 Guides authored
Baylor, Team S1-G1, Johnson Spring 2018 Member of Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 24
All Time: 999
