B-Flat Clarinet Key Pad Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
114
All Time:
2,178
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
While a clarinet is used in this guide, this technique could be used on other woodwind instruments. A pad on a clarinet needs to be replaced if it falls off or becomes damaged. In this case, the protective film on the pad has fallen off.
Tools
    1. B-Flat Clarinet Key Pad Replacement, Key Pad: step 1, image 1 of 1
      • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
      • If the pad is missing completely, skip to step 3.
      Ask FixBot
    2. B-Flat Clarinet Key Pad Replacement: step 2, image 1 of 1
      • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
      Ask FixBot
    3. B-Flat Clarinet Key Pad Replacement: step 3, image 1 of 1
      • Squeeze a dot of super glue into the empty key.
      • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
      Ask FixBot
    4. B-Flat Clarinet Key Pad Replacement: step 4, image 1 of 1
      • Quickly insert the new pad into the key, taking care not to smear the glue.
      Ask FixBot
    5. B-Flat Clarinet Key Pad Replacement: step 5, image 1 of 1
      • Using the screwdriver, press the pad down to secure it to the key
      • Hold the pad for 5 seconds to let the glue harden
      Ask FixBot
    6. B-Flat Clarinet Key Pad Replacement: step 6, image 1 of 1
      • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
      • Let the instrument sit out for a few minutes to let the glue fully dry
      Ask FixBot
Finish Line
Rachel Strobel
101 Reputation
1 Guide authored
1 Guide Comment
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 114
All Time: 2,178
