Azpen A740 Speaker Replacement
    1. Azpen A740 Speaker Replacement, Back Panel: step 1, image 1 of 1
      • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
      Ask FixBot
    1. Azpen A740 Speaker Replacement, Speaker: step 2, image 1 of 2 Azpen A740 Speaker Replacement, Speaker: step 2, image 2 of 2
      • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
      Ask FixBot
    2. Azpen A740 Speaker Replacement: step 3, image 1 of 2 Azpen A740 Speaker Replacement: step 3, image 2 of 2
      • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: How To Solder and Desolder Connections
      • After switching out the old speaker, just follow the directions in reverse to finish.
      Ask FixBot
Mallory
346 Reputation
3 Guides authored
USF Tampa, Team 4-5, Brown Winter 2015 Member of USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 331
