Up to 20% off select tools
Azpen A740 Battery Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
89
All Time:
2,210
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you can no longer use your Azpen A740 tablet because the battery no longer holds a charge or has malfunctioned, and you cannot use your device as a result, use this guide to replace the battery.
Before beginning this repair, power off your device and unplug from the charger.
    1. Azpen A740 Battery Replacement, Back Panel: step 1, image 1 of 1
      • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
      Ask FixBot
    1. Azpen A740 Battery Replacement, Battery: step 2, image 1 of 2 Azpen A740 Battery Replacement, Battery: step 2, image 2 of 2
      • Use the set of plastic opening tools to separate the inner backing from the electronics.
      • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
      Ask FixBot
    2. Azpen A740 Battery Replacement: step 3, image 1 of 1
      • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
      • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
      Ask FixBot
    3. Azpen A740 Battery Replacement: step 4, image 1 of 2 Azpen A740 Battery Replacement: step 4, image 2 of 2
      • Remove the black tape that is holding the battery in place.
      Ask FixBot
    4. Azpen A740 Battery Replacement: step 5, image 1 of 1
      • Remove the battery from the case using the blue prying or black spudger.
      • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
      Ask FixBot
Author
with
Maile Sinclair
228 Reputation
2 Guides authored
USF Tampa, Team 4-5, Brown Winter 2015 Member of USF Tampa, Team 4-5, Brown Winter 2015
USFT-BROWN-W15S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 89
All Time: 2,210
