Up to 20% off select tools
Azpen A720 Battery Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
96
All Time:
2,903
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The battery is important for all tablet functions. If the battery is malfunctioning you will want to replace it. Replacing your battery is a relatively simple task and following this guide will help you fix your battery related problems.
    1. Azpen A720 Battery Replacement, Back Cover: step 1, image 1 of 2 Azpen A720 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Ask FixBot
    2. Azpen A720 Battery Replacement: step 2, image 1 of 3 Azpen A720 Battery Replacement: step 2, image 2 of 3 Azpen A720 Battery Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Ask FixBot
    3. Azpen A720 Battery Replacement: step 3, image 1 of 1
      • Remove the rear casing.
      Ask FixBot
    1. Azpen A720 Battery Replacement, Battery: step 4, image 1 of 1
      • Locate the batteries' connection points.
      Ask FixBot
    2. Azpen A720 Battery Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • A soldering iron can reach 600Ëš F, which will cause serious burns. Learn how to solder properly here. Using tweezers to hold the wires will reduce the risk of burns.
      • Use a soldering iron to melt the connections which attach the battery to the motherboard.
      • Disconnect the red and black wires from the motherboard.
      Ask FixBot
    3. Azpen A720 Battery Replacement: step 6, image 1 of 2 Azpen A720 Battery Replacement: step 6, image 2 of 2
      • Peel the black sticker off the battery to disconnect the wifi antennae.
      Ask FixBot
    4. Azpen A720 Battery Replacement: step 7, image 1 of 3 Azpen A720 Battery Replacement: step 7, image 2 of 3 Azpen A720 Battery Replacement: step 7, image 3 of 3
      • Slide the spudger between the battery and the metal backing. Move the spudger back and forth in a sawing motion to break the adhesive seal between the battery and the backing.
      • When the spudger is underneath the battery avoid prying. A prying motion could damage the battery.
      Ask FixBot
    5. Azpen A720 Battery Replacement: step 8, image 1 of 2 Azpen A720 Battery Replacement: step 8, image 2 of 2
      • Remove the old battery and replace it with the new battery.
      Ask FixBot
Finish Line
Author
with
Ben
280 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 96
All Time: 2,903
