Up to 20% off select tools
Azpen A720 Back Cover Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
78
All Time:
1,024
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
All of the key components that could fail are accessed by removing the Azpen A720 back cover. The process will include removing a couple of screws and then utilizing the plastic opening tool to pry the cover apart from the body of the device.
    1. Azpen A720 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Azpen A720 Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
      Ask FixBot
    2. Azpen A720 Back Cover Replacement: step 2, image 1 of 3 Azpen A720 Back Cover Replacement: step 2, image 2 of 3 Azpen A720 Back Cover Replacement: step 2, image 3 of 3
      • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
      • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
      Ask FixBot
    3. Azpen A720 Back Cover Replacement: step 3, image 1 of 1
      • Remove the rear casing.
      Ask FixBot
Author
with
Ben
280 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 78
All Time: 1,024
