Introduction
Replacing the motherboard requires the removal of only a few screws and wires. Always remember to be gentle when handling the device, never replace parts inside the device when the power is on, and to avoid touching any parts without being properly grounded.
Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
