Up to 20% off select tools
Azpen A701 Charger Port Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
90
All Time:
1,171
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
The charger port is located on the motherboard (the blue L-shaped piece) at the bottom of the device. In order to replace the port, a soldering kit is needed. Be sure you have all the necessary tools and safety equipment on hand before starting.
A guide to soldering can be found on iFixit's website here.
    1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
      • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
      Ask FixBot
    2. Azpen A701 Charger Port  Replacement: step 2, image 1 of 2 Azpen A701 Charger Port  Replacement: step 2, image 2 of 2
      • Pry open the back piece with the plastic spudger.
      • Remove the back piece from the device.
      • The back panel may be difficult to pry off, use gentle force.
      Ask FixBot
    3. Azpen A701 Charger Port  Replacement: step 3, image 1 of 1
      • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
      Ask FixBot
    4. Azpen A701 Charger Port  Replacement: step 4, image 1 of 1
      • Gently pry the battery off of the device with the plastic spudger.
      • There is a large amount of glue holding the battery to the device.
      • Do not puncture the battery with the plastic spudger.
      Ask FixBot
    1. Azpen A701 Charger Port  Replacement, Charger Port: step 5, image 1 of 1
      • The charger port is located on the underside of the motherboard (as pictured).
      Ask FixBot
    2. Azpen A701 Charger Port  Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the charger port by using tweezers and gently pulling.
      Ask FixBot
    3. Azpen A701 Charger Port  Replacement: step 7, image 1 of 1
      • Solder and place new charger port.
      Ask FixBot
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Author
with
Michael
568 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 90
All Time: 1,171
