Up to 20% off select tools
Azpen A701 Battery Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
89
All Time:
1,366
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
The battery in the A701 is located adjacent to the motherboard (the blue L-shaped piece) and has soldered wires. Before continuing, be sure you have all the necessary tools and safety equipment.
A guide to soldering can be found here.
    1. Azpen A701 Battery Replacement, General Disassembly Prerequisite Guide: step 1, image 1 of 1
      • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
      Ask FixBot
    2. Azpen A701 Battery Replacement: step 2, image 1 of 2 Azpen A701 Battery Replacement: step 2, image 2 of 2
      • Pry open the back piece with the plastic spudger.
      • Remove the back piece from the device.
      • The back panel may be difficult to pry off, use gentle force.
      Ask FixBot
    3. Azpen A701 Battery Replacement: step 3, image 1 of 1
      • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
      Ask FixBot
    4. Azpen A701 Battery Replacement: step 4, image 1 of 1
      • Gently pry the battery off of the device with the plastic spudger.
      • There is a large amount of glue holding the battery to the device.
      • Do not puncture the battery with the plastic spudger.
      Ask FixBot
    1. Azpen A701 Battery Replacement, Battery: step 5, image 1 of 1
      • Remove red and black wires leading from the battery to the motherboard by heating up a soldering iron and applying to area and gently removing wires.
      • For more information on soldering, please refer to iFixit's guide here.
      Ask FixBot
    2. Azpen A701 Battery Replacement: step 6, image 1 of 1
      • Insert new battery by soldering red and black wires onto the motherboard.
      • Make sure to solder the wires back on in the correct configuration (as pictured).
      Ask FixBot
Author
with
Grant Harding
249 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 89
All Time: 1,366
