Azpen A1045 Battery Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
14
Past 30 Days:
69
All Time:
382
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will walk you through replacing the faulty battery in the Azpen A1045 tablet. If your device isn’t powering on, drains quickly, or overheats, these could be signs of a faulty battery. The battery is crucial for powering the device, and replacing it will restore normal functionality. Be sure to power off the tablet and disconnect the battery before starting the repair. Handle the battery with care, especially if it is swollen, as it can be hazardous.
Tools
    1. Azpen A1045 Battery Replacement, Back Cover: step 1, image 1 of 2 Azpen A1045 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Power off the tablet by holding the side button for five seconds.
      • Insert an opening tool into one of the sides and lift until the screen comes off.
      • This tablet is secured by clips on the sides; no adhesive is used.
      Ask FixBot
    1. Azpen A1045 Battery Replacement, Battery: step 2, image 1 of 2 Azpen A1045 Battery Replacement, Battery: step 2, image 2 of 2
      • After heating your soldering iron, place it on the black wire and desolder it.
      • Repeat the same step for the red wire.
      • For more information on soldering, check out this guide.
      Ask FixBot
    2. Azpen A1045 Battery Replacement: step 3, image 1 of 2 Azpen A1045 Battery Replacement: step 3, image 2 of 2
      • Warning: Be careful not to puncture the battery, as doing so could cause it to explode.
      • Insert an iFixit opening tool beneath the battery and gently pry it up.
      • If you're having trouble removing the adhesive, use 91% or higher isopropyl alcohol. Apply it in small quantities with a syringe, if possible, to avoid damaging any electrical components.
      • After removing the battery, clean the area where the adhesive was, so it's ready for the new battery.
      Ask FixBot
3 other people completed this guide.
Alaa Kaliny
335 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 69
All Time: 382
