Axess TA2513-10WT Side Button Replacement
    1. Axess TA2513-10WT Side Button Replacement, Back Cover: step 1, image 1 of 1
      • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
      Ask FixBot
    2. Axess TA2513-10WT Side Button Replacement: step 2, image 1 of 3 Axess TA2513-10WT Side Button Replacement: step 2, image 2 of 3 Axess TA2513-10WT Side Button Replacement: step 2, image 3 of 3
      • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
      • Slide the plastic opening tool gently along the sides.
      • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
      Ask FixBot
    3. Axess TA2513-10WT Side Button Replacement: step 3, image 1 of 1
      • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
      Ask FixBot
    4. Axess TA2513-10WT Side Button Replacement: step 4, image 1 of 1
      • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
      Ask FixBot
    1. Axess TA2513-10WT Side Button Replacement, Buttons: step 5, image 1 of 2 Axess TA2513-10WT Side Button Replacement, Buttons: step 5, image 2 of 2
      • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
      Ask FixBot
    2. Axess TA2513-10WT Side Button Replacement: step 6, image 1 of 2 Axess TA2513-10WT Side Button Replacement: step 6, image 2 of 2
      Tool used on this step:
      Buy
      • Unlatch the clear rubber holder from the posts with the tweezers.
      Ask FixBot
    3. Axess TA2513-10WT Side Button Replacement: step 7, image 1 of 2 Axess TA2513-10WT Side Button Replacement: step 7, image 2 of 2
      • With tweezers, pull the rubber holder from the back cover completely.
      Ask FixBot
    4. Axess TA2513-10WT Side Button Replacement: step 8, image 1 of 3 Axess TA2513-10WT Side Button Replacement: step 8, image 2 of 3 Axess TA2513-10WT Side Button Replacement: step 8, image 3 of 3
      • Remove the individual buttons with tweezers.
      Ask FixBot
Lori Scott
101 Reputation
1 Guide authored
Baylor, Team 6-3, Shaver Spring 2015 Member of Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 539
