Up to 20% off select tools
Axess SPBT1031 Subwoofer Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
95
All Time:
2,352
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace Axess SPBT1031 Subwoofer. Replacing the subwoofer is moderate difficulty and it'll take about 15 minutes to replace. Below is the step-by-step guide to replacing the subwoofer.
    1. Axess SPBT1031 Subwoofer Replacement, Subwoofer: step 1, image 1 of 1
      • Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
      • Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
      • Do not remove the plate yet.
      Ask FixBot
    2. Axess SPBT1031 Subwoofer Replacement: step 2, image 1 of 1
      • Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
      Ask FixBot
    3. Axess SPBT1031 Subwoofer Replacement: step 3, image 1 of 2 Axess SPBT1031 Subwoofer Replacement: step 3, image 2 of 2
      • Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      • For subwoofer replacement there will be four screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed.
      Ask FixBot
    4. Axess SPBT1031 Subwoofer Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • If the screws are difficult to remove, use the tweezers to twist and pick them out.
      Ask FixBot
    5. Axess SPBT1031 Subwoofer Replacement: step 5, image 1 of 1
      • Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
      • Be careful not to damage the black face plate or red plate as you pull them apart.
      • You may place the black faceplate back on the tube, but do not screw it back in yet.
      Ask FixBot
    6. Axess SPBT1031 Subwoofer Replacement: step 6, image 1 of 2 Axess SPBT1031 Subwoofer Replacement: step 6, image 2 of 2
      • To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
      Ask FixBot
    7. Axess SPBT1031 Subwoofer Replacement: step 7, image 1 of 1
      Desoldering Pump
      $3.99
      Buy
      Ask FixBot
    8. Axess SPBT1031 Subwoofer Replacement: step 8, image 1 of 1
      • Remove the old subwoofer.
      • Connect the brown wires to the positive terminals and the black ones to the negative terminals when re-soldering.
      Ask FixBot
2 other people completed this guide.
Author
with
Elvira Lou Evangelista
975 Reputation
6 Guides authored
1 Guide Comment
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
Ramon lopez - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 95
All Time: 2,352
