Axess SPBT1031 Speaker (Horns) Replacement
  1. Axess SPBT1031 Speaker (Horns) Replacement, Black Faceplate: step 1, image 1 of 1
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
    Ask FixBot
  2. Axess SPBT1031 Speaker (Horns) Replacement: step 2, image 1 of 1
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
    Ask FixBot
  3. Axess SPBT1031 Speaker (Horns) Replacement, Speaker (Horns): step 3, image 1 of 1
    • By this point you should have determined which speaker needs to be replaced, to figure this out please refer back to the troubleshooting guide.
    • For the top horn replacement, you will be working with the blue and white wire pair.
    • For the bottom horn replacement you with the yellow and white wire pair.
    Ask FixBot
  4. Axess SPBT1031 Speaker (Horns) Replacement: step 4, image 1 of 2 Axess SPBT1031 Speaker (Horns) Replacement: step 4, image 2 of 2
    • To remove the plastic coating around the desired horn, look on the back of the black face plate you removed and use the philips head ph1 screwdriver fitting to remove the two 0.3 cm Philips Head screw and washer combos on the left and right of the horn.
    • Screw depth of 0.7 cm
    Ask FixBot
  5. Axess SPBT1031 Speaker (Horns) Replacement: step 5, image 1 of 1
    • Lift the horn from its fitting by pulling it. Position it in a manner that is easy to work with.
    Ask FixBot
  6. Axess SPBT1031 Speaker (Horns) Replacement: step 6, image 1 of 2 Axess SPBT1031 Speaker (Horns) Replacement: step 6, image 2 of 2
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Use a soldering iron to heat the two contact points.
    • Then use a desoldering pump to remove the liquid solder.
    Ask FixBot
  7. Axess SPBT1031 Speaker (Horns) Replacement: step 7, image 1 of 1
    • Remove the wires--blue or yellow wire depending on the horn you are replacing--from the old speaker and remove the speaker from the fitting location.
    • For the bottom horn replacement, you will be working with the yellow and white wire pair.
    Ask FixBot
3 other people completed this guide.
Elvira Lou Evangelista
975 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 2,252
