Up to 20% off select tools
Axess SPBT1031 Battery Replacement
Views: 9.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
109
All Time:
9,785
Comments: 7
4 comments on steps, 3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will be helpful for repairing the battery if the troubleshooting page recommends that you replace the battery. This is a necessary step when you have determined no other way to repair your current battery. Be wary of accidentally damaging other parts of the device when replacing the battery.
    1. Axess SPBT1031 Battery Replacement, Red Interface Plate: step 1, image 1 of 1
      • Use a metal spudger to remove the mesh speaker covers (the side with the buttons) by wedging the narrow end into the center of the outer edge of the mesh, touching the red plate.
      Ask FixBot
    2. Axess SPBT1031 Battery Replacement: step 2, image 1 of 1
      • Remove the four 5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
      Ask FixBot
    3. Axess SPBT1031 Battery Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • If the screws are difficult to remove, use a pair of tweezers to twist and pick them out.
      Ask FixBot
    4. Axess SPBT1031 Battery Replacement: step 4, image 1 of 1
      • Separate the red interface plate from the black face plate by pulling them apart.
      Ask FixBot
    1. Axess SPBT1031 Battery Replacement, Black Faceplate: step 5, image 1 of 1
      • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
      • Both screws are 0.55 cm in depth
      Ask FixBot
    2. Axess SPBT1031 Battery Replacement: step 6, image 1 of 1
      • Separate the black face plate from the tube by pulling them apart.
      • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
      Ask FixBot
    1. Axess SPBT1031 Battery Replacement, Battery: step 7, image 1 of 1
      • Look into the back of the black face plate and find the battery which is wrapped in green.
      • Battery is glued in place, remove by peeling it off.
      Ask FixBot
    2. Axess SPBT1031 Battery Replacement: step 8, image 1 of 1
      • Once the glue is removed, look into the red interface plate and then locate the bottom of the motherboard.
      • On the bottom of the motherboard, locate the black and red wire connected to the plastic red socket and remove the white insert from this socket.
      Ask FixBot
    3. Axess SPBT1031 Battery Replacement: step 9, image 1 of 1
      • Run the black and red wire in reverse through the hole in the black face plate to remove the battery.
      • Remove the battery from the black face plate.
      Ask FixBot
2 other people completed this guide.
Author
with
Elvira Lou Evangelista
975 Reputation
6 Guides authored
3 Guide Comments
ok, so is there any reason that I would not be able to put in a bigger battery for longer play? I realize I would have to mount it differently.
bartman777 - Reply Share
why it is easily connect this blue tooth to cellphone done connecting to computer. Well not connect any of my 3 laptop computer ??????????????
htosee3791 - Reply Share
What battery is used for the speaker?
De'Eric Dortch - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 109
All Time: 9,785
