Up to 20% off select tools
Avid Fast Track Solo Disassembly
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
72
All Time:
542
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Full disassembly and teardown of the Avid Fast Track Solo audio interface.
Follow this teardown to take off the chassis and access the internals of the Avid Fast Track Solo. This teardown can also be used in order to access, clean, or replace potentiometers or other components.
Before you begin, completely unplug all cables from this unit.
    1. Avid Fast Track Solo Disassembly, Getting Started: step 1, image 1 of 1
      • Remove all cables from the unit.
      Ask FixBot
    2. Avid Fast Track Solo Disassembly, Remove the knobs: step 2, image 1 of 3 Avid Fast Track Solo Disassembly, Remove the knobs: step 2, image 2 of 3 Avid Fast Track Solo Disassembly, Remove the knobs: step 2, image 3 of 3
      • Remove all three knobs on the front by pulling them straight out.
      • One may insert one or two iFixit picks underneath the knobs to pry them out.
      Ask FixBot
    3. Avid Fast Track Solo Disassembly, Open the front cover: step 3, image 1 of 3 Avid Fast Track Solo Disassembly, Open the front cover: step 3, image 2 of 3 Avid Fast Track Solo Disassembly, Open the front cover: step 3, image 3 of 3
      • Turn the unit upside down.
      • Insert an iFixit pick in the ridge between the body and the front plate, start in front of the feet pads and work around the unit.
      • Carefully pry of the front plate.
      Ask FixBot
    4. Avid Fast Track Solo Disassembly, Remove washers: step 4, image 1 of 1
      • Use pliers to loosen the washers on the three potentiometer stems. The washers can then be unscrewed by hand.
      • Use pliers to loosen the washers holding the two 6.3 mm jacks. The washers can then be unscrewed by hand.
      • Be careful not to hit the small lights to the right of each 6.3 mm jack when loosening the washers.
      Ask FixBot
    5. Avid Fast Track Solo Disassembly, Unscrew screws: step 5, image 1 of 2 Avid Fast Track Solo Disassembly, Unscrew screws: step 5, image 2 of 2
      • Unscrew all the screws fitted on the front plate, in the following order:
      • Use a PH1 screwdriver to remove the two PH1 screws securing the XLR jack.
      • Use a PH2 screwdriver to remove the remaining PH2 screws securing the front metal plate to the chassis.
      • The Direct Monitor button hat (between the two 6.3 mm jacks) can be left as is throughout the whole disassembly, alternatively it can be remove by gently pulling it straight out.
      Ask FixBot
    6. Avid Fast Track Solo Disassembly, Remove the front plate: step 6, image 1 of 3 Avid Fast Track Solo Disassembly, Remove the front plate: step 6, image 2 of 3 Avid Fast Track Solo Disassembly, Remove the front plate: step 6, image 3 of 3
      • The front plate should sit loose on the body without any screws holding it.
      • Remove the front metal plate.
      • One may slide an iFixit pick in the seam between the front metal plate and the metal chassis if the plate does not fall off and all screws are loosened.
      Ask FixBot
    7. Avid Fast Track Solo Disassembly, Remove the rear cover: step 7, image 1 of 3 Avid Fast Track Solo Disassembly, Remove the rear cover: step 7, image 2 of 3 Avid Fast Track Solo Disassembly, Remove the rear cover: step 7, image 3 of 3
      • To remove the motherboard, it is necessary to first unscrew the screws securing it from the rear of the unit.
      • Turn the unit upside down. Face the rear of the unit.
      • Insert an iFixit pick in the ridge between the body and the back cover, start behind the feet pads and work around the unit.
      • Carefully pry off the plastic rear cover.
      Ask FixBot
    8. Avid Fast Track Solo Disassembly, Remove the rear plate: step 8, image 1 of 2 Avid Fast Track Solo Disassembly, Remove the rear plate: step 8, image 2 of 2
      • Unscrew all the screws fitted on the rear plate.
      • Only the screws marked in red need to be removed in order to detach the motherboard.
      • Use a PH2 screwdriver to remove the PH2 screws securing the motherboard.
      • Use a PH2 screwdriver to remove the remaining PH2 screws which are securing the rear metal plate to the chassis.
      • (optional) Remove the front metal plate.
      Ask FixBot
    9. Avid Fast Track Solo Disassembly, Remove the motherboard: step 9, image 1 of 3 Avid Fast Track Solo Disassembly, Remove the motherboard: step 9, image 2 of 3 Avid Fast Track Solo Disassembly, Remove the motherboard: step 9, image 3 of 3
      • To orient the unit, see the purple AVID logo on the top of the unit. The text is readable as AVID in correct orientation from the front of the unit.
      • Face the front of the unit.
      • Gently pull out the motherboard by pulling the black post attached to the motherboard. The motherboard should slide out without any resistance.
      • Alternatively, the motherboard can be pulled out from the rear of the unit by pulling the black posts attached to the rear of the motherboard.
      • The full teardown is now complete!
      Ask FixBot
    10. Avid Fast Track Solo Disassembly, Reattach the rear plate: step 10, image 1 of 2 Avid Fast Track Solo Disassembly, Reattach the rear plate: step 10, image 2 of 2
      • This step can be skipped if the rear plate was not removed.
      • Face the rear of the unit.
      • Reattach the rear plate.
      • Reinsert and tighten the PH2 screws holding the rear plate to the chassis.
      • Do not reinsert the two screws which secures the motherboard.
      Ask FixBot
    11. Avid Fast Track Solo Disassembly, Insert the motherboard: step 11, image 1 of 3 Avid Fast Track Solo Disassembly, Insert the motherboard: step 11, image 2 of 3 Avid Fast Track Solo Disassembly, Insert the motherboard: step 11, image 3 of 3
      • Gently insert the motherboard back into the chassis, all the way in. The motherboard is to rest on the lower lip.
      Ask FixBot
    12. Avid Fast Track Solo Disassembly, Secure the motherboard and the rear cover: step 12, image 1 of 2 Avid Fast Track Solo Disassembly, Secure the motherboard and the rear cover: step 12, image 2 of 2
      • Reinsert and tighten the two PH2 screws securing the motherboard.
      • Reattach the plastic rear cover by pressing it on. Put pressure on the sides, and work around the unit.
      Ask FixBot
    13. Avid Fast Track Solo Disassembly, Reattach the potentiometers to front plate: step 13, image 1 of 3 Avid Fast Track Solo Disassembly, Reattach the potentiometers to front plate: step 13, image 2 of 3 Avid Fast Track Solo Disassembly, Reattach the potentiometers to front plate: step 13, image 3 of 3
      • Insert the three potentiometers into the front plate.
      • Each potentiometer has a small prong that is to be fitted through the front plate, either to the right or below the potentiometer stem.
      • Reattach and tighten the washers for the potentiometers.
      Ask FixBot
    14. Avid Fast Track Solo Disassembly, Reattach the front plate: step 14, image 1 of 3 Avid Fast Track Solo Disassembly, Reattach the front plate: step 14, image 2 of 3 Avid Fast Track Solo Disassembly, Reattach the front plate: step 14, image 3 of 3
      • Reinsert and tighten all screws into the front plate, in the following order:
      • Reinsert and tighten all PH2 screws securing the front plate to the chassis.
      • Reinsert and tighten the two PH1 screws securing the XLR jack into the front plate.
      • Some force is needed to screw the two PH1 screws back into the XLR jack. Be cautious to not over tighten the screws!
      • Reattach and tighten the washers for the two 6.3 mm jacks.
      • Use pliers to make sure the washers for the potentiometers and the 6.3 mm jacks all are tight and secured.
      • Be careful not to hit the small lights to the right of each 6.3 mm jack when tightening the washers.
      • If the Direct Monitor button cap (between the two 6.3mm jacks) were previously removed, please reattach it by gently pressing it into place.
      Ask FixBot
    15. Avid Fast Track Solo Disassembly, Reattach the front cover: step 15, image 1 of 2 Avid Fast Track Solo Disassembly, Reattach the front cover: step 15, image 2 of 2
      • Reattach the plastic front cover by pressing it on. Put pressure on the sides, and work around the edges of the unit.
      Ask FixBot
    16. Avid Fast Track Solo Disassembly, Reattach the knobs: step 16, image 1 of 3 Avid Fast Track Solo Disassembly, Reattach the knobs: step 16, image 2 of 3 Avid Fast Track Solo Disassembly, Reattach the knobs: step 16, image 3 of 3
      • When attaching the knobs, leave a tiny gap, or press an iFixit pick between the base of the knob and the front cover of the unit. This is to ensure that the knobs does not scratch against the cover.
      • Attach all three knobs to the potentiometer stems by pressing them straight on. They are interchangeable and the knobs will only fit in one orientation on the stems.
      Ask FixBot
Congratulations! You are now done!
Author
with
MeekVixen
11,237 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 72
All Time: 542
