Up to 20% off select tools
Autosampler Programming (For Old & New Versions)
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
72
All Time:
707
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: step 1, image 1 of 2 Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: step 1, image 2 of 2
      • 1. Switch battery "ON".
      • 2. Autosampler: Push "ON" button.
      • It will say ...STANDBY...
      Ask FixBot
    2. Autosampler Programming  (For Old & New Versions), Select Program Mode: step 2, image 1 of 2 Autosampler Programming  (For Old & New Versions), Select Program Mode: step 2, image 2 of 2
      • 3. Push "ENTER/PROGRAM" button to see the "[PROGRAM, CONFIGURE] SAMPLER" screen. Push “ENTER/PROGRAM” button to select "PROGRAM".
      • 4. This will bring up the "[TIME, FLOW] PACED SAMPLING" screen. Use arrow to select "FLOW" then push “ENTER/PROGRAM” button.
      Ask FixBot
    3. Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: step 3, image 1 of 3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: step 3, image 2 of 3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: step 3, image 3 of 3
      • 5. New screen shows: "SAMPLE EVERY __ PULSES." Press 20. Then push the “ENTER/PROGRAM” button.
      • 6. New screen will read: "MULTIPLEX SAMPLES?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button.
      • 7. New screen will read: "SAMPLE VOLUMES OF "____" ML". Press 1000. Then push the “ENTER/PROGRAM” button.
      Ask FixBot
    4. Autosampler Programming  (For Old & New Versions), Starting Sampling: step 4, image 1 of 3 Autosampler Programming  (For Old & New Versions), Starting Sampling: step 4, image 2 of 3 Autosampler Programming  (For Old & New Versions), Starting Sampling: step 4, image 3 of 3
      • 8. New screen will read: "ENTER START TIME?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button. New screen: "PROGRAMMING SEQUENCE COMPLETE...". Then screen will read: "PROGRAM HALTED".
      • 9. Push "START SAMPLING" button. Screen will read: "[START, RESUME] SAMPLING PROGRAM?" Push "ENTER/PROGRAM" button to "START". Then push "ENTER/PROGRAM" button again to "START SAMPLING AT BOTTLE 1".
      • 10. Then should see on screen: "START FLOW COUNT AT __:__" (time).
      • It will take some time before it starts sampling.
      • Eventually screen will show: " BOTTLE 1 AFTER 20 PULSES".
      Ask FixBot
Finish Line
Author
with
Brooke Mason
2,958 Reputation
17 Guides authored
Open-Storm Member of Open-Storm
Community
16 Members
276 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 72
All Time: 707
