Up to 20% off select tools
Automatic Tommy 20 Trigger Spring Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
111
All Time:
1,639
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You will need to have a #00 Phillips screw driver and a great attitude to replace this important component of your gun! Also, watch out for all the small parts such as the spring itself, they are easy to lose track of! Also cracking the gun open may make you nervous but just take each step one at a time and you will be fine.
    1. Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: step 1, image 1 of 2 Automatic Tommy 20 Trigger Spring Replacement, Splitting the Gun into Two Halves: step 1, image 2 of 2
      • Locate the orange slider on the front side of the gun.
      • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
      Ask FixBot
    2. Automatic Tommy 20 Trigger Spring Replacement: step 2, image 1 of 3 Automatic Tommy 20 Trigger Spring Replacement: step 2, image 2 of 3 Automatic Tommy 20 Trigger Spring Replacement: step 2, image 3 of 3
      • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
      • Remove all parts within the chamber to be able to completely detach the nose of the gun.
      • Be careful to keep track of all the components for reassembly.
      Ask FixBot
    1. Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: step 3, image 1 of 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: step 3, image 2 of 3 Automatic Tommy 20 Trigger Spring Replacement, Ammo Drum: step 3, image 3 of 3
      • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
      • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
      Ask FixBot
    2. Automatic Tommy 20 Trigger Spring Replacement: step 4, image 1 of 1
      • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
      Ask FixBot
    1. Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: step 5, image 1 of 2 Automatic Tommy 20 Trigger Spring Replacement, Split the Gun into Two Halves: step 5, image 2 of 2
      • Grab both sides of the gun and pull forcefully in an upward and outward motion to remove from the light green stock.
      • If this is your first time disassembling your gun, the stock will be glued to each half of the gun's body. To break off the stock from the frame of the gun, you will need to careful wiggle the two halves so that the glue will break apart. The plastic on the gun may break or warp slightly.
      Ask FixBot
    2. Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: step 6, image 1 of 2 Automatic Tommy 20 Trigger Spring Replacement, Removing the Battery Box: step 6, image 2 of 2
      • Remove the two 1/16 in. screws attaching the battery box to the frame of the gun using a Phillips #00 Screwdriver.
      • Lift the battery box off the frame of the gun to give yourself access to the trigger mechanism.
      Ask FixBot
    3. Automatic Tommy 20 Trigger Spring Replacement, Removing the Screws from the Trigger Mechanism: step 7, image 1 of 1
      • Remove the two 1/6 in. screws connecting the trigger and trigger spring to the frame of the gun using a Phillips #00 Screwdriver.
      Ask FixBot
    4. Automatic Tommy 20 Trigger Spring Replacement: step 8, image 1 of 2 Automatic Tommy 20 Trigger Spring Replacement: step 8, image 2 of 2
      • Lift the plastic trigger away from the gun along with the attached spring.
      • Make sure you do not lift the trigger without the spring or the spring may stretch and no longer function properly.
      Ask FixBot
2 other people completed this guide.
Author
with
Moira Foster
419 Reputation
3 Guides authored
Cal Poly, Team 6-22, Maness Fall 2014 Member of Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 111
All Time: 1,639
