Automatic Tommy 20 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
97
All Time:
1,104
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Replacing the battery in the Tommy 20 is a relatively simple replacement, just make sure you have 3 replacement AA batteries ready to go beforehand along with a Phillips #1 Screwdriver! A good first step in any repair goal concerning the Tommy 20!
Parts
Tools
    1. Automatic Tommy 20 Battery Replacement, Removing the Battery Cover: step 1, image 1 of 2 Automatic Tommy 20 Battery Replacement, Removing the Battery Cover: step 1, image 2 of 2
      • Remove the single 1mm screw connecting the battery cover to the gun using a Phillips #1 screwdriver.
      • Lift the cover away from the gun and remove.
      Ask FixBot
    2. Automatic Tommy 20 Battery Replacement, Remove the Batteries: step 2, image 1 of 2 Automatic Tommy 20 Battery Replacement, Remove the Batteries: step 2, image 2 of 2
      • Remove all three batteries from compartment by pulling up on the positive end of each battery.
      Ask FixBot
Reed Garmsen
468 Reputation
2 Guides authored
Cal Poly, Team 6-22, Maness Fall 2014 Member of Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 97
All Time: 1,104
