Up to 20% off select tools
Auking M8-F PCB Button Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
57
All Time:
539
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the power panel on your AuKing M8-F projector.
The power panel is a component found on devices responsible for controlling whether the device is powered on and functioning or turned off, conserving power and the state of the other components. A faulty power panel could lead to problems like turning the device on and off. This could over time damage the condition of certain components making them less functional.
If you are experiencing issues with the power button or the rest of the button panel, please take a look at the troubleshooting page to find another possible cause for your condition. If no other condition matches your problem, then the power panel might be the problem.
Before continuing this guide, be sure to turn off your projector completely.
    1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: step 1, image 1 of 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: step 1, image 2 of 2
      • Make sure that the device is unplugged from any power source before attempting any repairs.
      • Flip the projector on its opposite side.
      • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
      • Remove the two 14 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    2. Auking M8-F PCB Button Panel Replacement: step 2, image 1 of 2 Auking M8-F PCB Button Panel Replacement: step 2, image 2 of 2
      • Carefully prop open the top of the projector.
      • Disconnect the cable attached to the top lid.
      • Remove the top lid.
      Ask FixBot
    3. Auking M8-F PCB Button Panel Replacement: step 3, image 1 of 2 Auking M8-F PCB Button Panel Replacement: step 3, image 2 of 2
      • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
      Ask FixBot
    4. Auking M8-F PCB Button Panel Replacement: step 4, image 1 of 3 Auking M8-F PCB Button Panel Replacement: step 4, image 2 of 3 Auking M8-F PCB Button Panel Replacement: step 4, image 3 of 3
      • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
      • Remove the power panel.
      Ask FixBot
Author
with
Aubrey Haynes
295 Reputation
3 Guides authored
1 Guide Comment
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 57
All Time: 539
