Audiovox CR8030iE5 Backlight Replacement
  1. Audiovox CR8030iE5 Backlight Replacement, Top-Casing: step 1, image 1 of 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
    Ask FixBot
  2. Audiovox CR8030iE5 Backlight Replacement: step 2, image 1 of 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
    Ask FixBot
  3. Audiovox CR8030iE5 Backlight Replacement: step 3, image 1 of 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
    Ask FixBot
  4. Audiovox CR8030iE5 Backlight Replacement: step 4, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
    Ask FixBot
  5. Audiovox CR8030iE5 Backlight Replacement: step 5, image 1 of 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
    Ask FixBot
  6. Audiovox CR8030iE5 Backlight Replacement, Backlight: step 6, image 1 of 1
    • Insert a Phillips #1 screwdriver into the corner, square, holes and push the backlight board up away from the plastic casing.
    Ask FixBot
  7. Audiovox CR8030iE5 Backlight Replacement: step 7, image 1 of 1
    • Carefully, pull up on the board to remove it entirely from the plastic casing.
    Ask FixBot
  8. Audiovox CR8030iE5 Backlight Replacement: step 8, image 1 of 1
    • Flip the backlight board over to view the underside.
    Ask FixBot
  9. Audiovox CR8030iE5 Backlight Replacement: step 9, image 1 of 1
    • One by one, de-solder the four wires (two wires corresponding to each LED bulb) that attach the backlight to the board.
    • If you don't know how to solder, check out How To Solder and Desolder Connections.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
    Ask FixBot
  10. Audiovox CR8030iE5 Backlight Replacement: step 10, image 1 of 1
    • Remove the two LED light bulbs.
    • Insert each wire from the new LED bulbs into the respective holes.
    Ask FixBot
  11. Audiovox CR8030iE5 Backlight Replacement: step 11, image 1 of 1
    • One by one, solder the backlight wires back into place.
    Ask FixBot
Nab Sengupta
55 Reputation
4 Guides authored
Cal Poly, Team 10-39, Amido Spring 2013 Member of Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 617
