Up to 20% off select tools
Audiovox CDM-8910 Keyboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
13
All Time:
1,897
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
    1. Audiovox CDM-8910 Keyboard Replacement, Antenna: step 1, image 1 of 1
      • Locate the antenna (shown in red box) at the top of the phone when closed.
      Ask FixBot
    2. Audiovox CDM-8910 Keyboard Replacement: step 2, image 1 of 1
      • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
      Ask FixBot
    1. Audiovox CDM-8910 Keyboard Replacement, Battery: step 3, image 1 of 1
      • Locate the back side of the phone.
      • The battery is the large main compartment (red box).
      Ask FixBot
    2. Audiovox CDM-8910 Keyboard Replacement: step 4, image 1 of 1
      • Use your finger to slide the latch (circled) upwards.
      • While holding the latch up, pull the battery off the phone.
      Ask FixBot
    3. Audiovox CDM-8910 Keyboard Replacement: step 5, image 1 of 1
      • The back of the phone will look like this when the battery is correctly removed.
      Ask FixBot
    1. Audiovox CDM-8910 Keyboard Replacement, Rear Case: step 6, image 1 of 1
      • Peel the rubber indicated toward the top of the phone
      Ask FixBot
    2. Audiovox CDM-8910 Keyboard Replacement: step 7, image 1 of 1
      • Remove the screw that sits underneath the rubber covering.
      Ask FixBot
    3. Audiovox CDM-8910 Keyboard Replacement: step 8, image 1 of 1
      • Remove the five (5) total screws using a Philips head screwdriver.
      Ask FixBot
    4. Audiovox CDM-8910 Keyboard Replacement: step 9, image 1 of 1
      • Use spudger and insert it towards the bottom of the phone as pictured.
      • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
      • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
      Ask FixBot
    5. Audiovox CDM-8910 Keyboard Replacement: step 10, image 1 of 1
      • The back case should now be completely removed and the motherboard will be visible.
      Ask FixBot
    1. Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 1 of 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 2 of 3 Audiovox CDM-8910 Keyboard Replacement, Motherboard: step 11, image 3 of 3
      • Disconnect the gold connection patch
      • Use a spudger or finger to disconnect the piece.
      Ask FixBot
    2. Audiovox CDM-8910 Keyboard Replacement: step 12, image 1 of 1
      • Using a spudger, lift the motherboard out of the phone case as pictured.
      Ask FixBot
    3. Audiovox CDM-8910 Keyboard Replacement: step 13, image 1 of 1
      • The motherboard should now be completely removed from the phone.
      Ask FixBot
    1. Audiovox CDM-8910 Keyboard Replacement, Keyboard: step 14, image 1 of 1
      • Once the motherboard has been removed, peel the keyboard as pictured.
      Ask FixBot
Author
with
Carlos Guerrero
1 Reputation
2 Guides authored
Cal Poly, Team 3-24, Regan Fall 2010 Member of Cal Poly, Team 3-24, Regan Fall 2010
CPSU-REGAN-F10S3G24
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 1,897
