Audiovox CDM-8900 Camera Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
22
Past 30 Days:
106
All Time:
2,987
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
If the camera on your Audiovox CDM-8900 is not working correctly or showing a black screen when trying to use the camera, then you might need a camera replacement.
There is no need to purchase a new phone. Just replace the camera!
Step 6 requires you to take the motherboard and simply add the new camera carefully and verify that the camera is oriented correctly when reinserting.
Remember to carefully place everything back to its original place.
Tools
    1. Audiovox CDM-8900 Camera Replacement, Battery: step 1, image 1 of 2 Audiovox CDM-8900 Camera Replacement, Battery: step 1, image 2 of 2
      • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
      Ask FixBot
    1. Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 1 of 3 Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 2 of 3 Audiovox CDM-8900 Camera Replacement, Antenna: step 2, image 3 of 3
      • Grasp the antenna at its base and twist to unscrew.
      • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
      Ask FixBot
    1. Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 1 of 3 Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 2 of 3 Audiovox CDM-8900 Camera Replacement, Motherboard: step 3, image 3 of 3
      • Remove the small rubber insert from the top of the phone to access the top screw.
      • Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
      • If screws do not slide out after unscrewing, gently flip and tap the phone in your hand until the screws come loose.
      Ask FixBot
    2. Audiovox CDM-8900 Camera Replacement: step 4, image 1 of 3 Audiovox CDM-8900 Camera Replacement: step 4, image 2 of 3 Audiovox CDM-8900 Camera Replacement: step 4, image 3 of 3
      • Wedge the phone plate toward you, using the leverage from an opening tool.
      • The volume control button on the left side of the phone will loosen. Make sure to carefully reinsert it during reassembly.
      • Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
      Ask FixBot
    3. Audiovox CDM-8900 Camera Replacement: step 5, image 1 of 3 Audiovox CDM-8900 Camera Replacement: step 5, image 2 of 3 Audiovox CDM-8900 Camera Replacement: step 5, image 3 of 3
      • To release the motherboard, push the large "OK" button located on the other side of the phone.
      • Before reassembly, make sure the keypad is lined up with the motherboard. Be sure the camera lens is properly aligned at the top of the motherboard and the volume controls are in place.
      Ask FixBot
    1. Audiovox CDM-8900 Camera Replacement, Camera: step 6, image 1 of 1
      • Grasp camera.
      • Slide the camera out of slot on the logic board.
      • Camera is difficult to reassemble; there is a white clip for easy camera replacement. Verify that you orient the camera correctly when reinserting.
      Ask FixBot
Aaron Shaw
177 Reputation
6 Guides authored
Cal Poly, Team 28-31, Regan Spring 2010 Member of Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 106
All Time: 2,987
