Audio-Technica ATH-M20xBT Microphone Replacement
  1. Audio-Technica ATH-M20xBT Microphone Replacement, Ear Pad: step 1, image 1 of 1
    • Place your fingers on the inside of the ear cup.
    Ask FixBot
  2. Audio-Technica ATH-M20xBT Microphone Replacement: step 2, image 1 of 2 Audio-Technica ATH-M20xBT Microphone Replacement: step 2, image 2 of 2
    • Gently pull the earpad outward, stretching the inner flap out of the plastic groove.
    Ask FixBot
  3. Audio-Technica ATH-M20xBT Microphone Replacement: step 3, image 1 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 3, image 2 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 3, image 3 of 3
    • Repeat for the other side if necessary.
    Ask FixBot
  4. Audio-Technica ATH-M20xBT Microphone Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 1 of 3 Audio-Technica ATH-M20xBT Microphone Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 2 of 3 Audio-Technica ATH-M20xBT Microphone Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 3 of 3
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the driver housing.
    • Gently lift driver assembly off with care not to strain the connected cables.
    • If necessary, insert an opening pick into the seam and pry up to lift the driver assembly.
    • The battery and daughterboard are accessible via the right housing. The motherboard (microphone, charging port, etc) is accessible via the left housing.
    Ask FixBot
  5. Audio-Technica ATH-M20xBT Microphone Replacement, Microphone: step 5, image 1 of 3 Audio-Technica ATH-M20xBT Microphone Replacement, Microphone: step 5, image 2 of 3 Audio-Technica ATH-M20xBT Microphone Replacement, Microphone: step 5, image 3 of 3
    • Use a Phillips screwdriver to remove the three 7 mm screws securing the white plate.
    • Carefully pop off the white plate.
    Ask FixBot
  6. Audio-Technica ATH-M20xBT Microphone Replacement: step 6, image 1 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 6, image 2 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 6, image 3 of 3
    • Use tweezers to carefully grab the red and black wires connected to the microphone (tiny gray box).
    • Gently lift the microphone from its housing.
    Ask FixBot
  7. Audio-Technica ATH-M20xBT Microphone Replacement: step 7, image 1 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 7, image 2 of 3 Audio-Technica ATH-M20xBT Microphone Replacement: step 7, image 3 of 3
    • Use a soldering iron to desolder the two microphone motherboard connections.
    • Fully remove the microphone.
    • If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 other people completed this guide.
Jameson Warby
716 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 58
All Time: 116
