Audio-Technica ATH-M20xBT Battery Replacement
  1. Audio-Technica ATH-M20xBT Battery Replacement, Ear Pad: step 1, image 1 of 1
    • Place your fingers on the inside of the ear cup.
    Ask FixBot
  2. Audio-Technica ATH-M20xBT Battery Replacement: step 2, image 1 of 2 Audio-Technica ATH-M20xBT Battery Replacement: step 2, image 2 of 2
    • Gently pull the earpad outward, stretching the inner flap out of the plastic groove.
    Ask FixBot
  3. Audio-Technica ATH-M20xBT Battery Replacement: step 3, image 1 of 3 Audio-Technica ATH-M20xBT Battery Replacement: step 3, image 2 of 3 Audio-Technica ATH-M20xBT Battery Replacement: step 3, image 3 of 3
    • Repeat for the other side if necessary.
    Ask FixBot
  4. Audio-Technica ATH-M20xBT Battery Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 1 of 3 Audio-Technica ATH-M20xBT Battery Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 2 of 3 Audio-Technica ATH-M20xBT Battery Replacement, Audio-Technica ATH-M20xBT Accessing the Internals: step 4, image 3 of 3
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the driver housing.
    • Gently lift driver assembly off with care not to strain the connected cables.
    • If necessary, insert an opening pick into the seam and pry up to lift the driver assembly.
    • The battery and daughterboard are accessible via the right housing. The motherboard (microphone, charging port, etc) is accessible via the left housing.
    Ask FixBot
  5. Audio-Technica ATH-M20xBT Battery Replacement, Battery: step 5, image 1 of 3 Audio-Technica ATH-M20xBT Battery Replacement, Battery: step 5, image 2 of 3 Audio-Technica ATH-M20xBT Battery Replacement, Battery: step 5, image 3 of 3
    • Use a small Phillips screwdriver to remove the three 7 mm screws from the white plate.
    • Carefully pop off the white plate.
    Ask FixBot
  6. Audio-Technica ATH-M20xBT Battery Replacement: step 6, image 1 of 1
    Ask FixBot
  7. Audio-Technica ATH-M20xBT Battery Replacement: step 7, image 1 of 1
    • Insert an opening pick under the battery and slide it under to sever the adhesive.
    • Take care not to bend, puncture, or warp the battery during removal.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 other people completed this guide.
Nyah Harrop
385 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 78
All Time: 179
