Audio Technica AT-LP60XUSB Turntable Belt Replacement
  1. Audio Technica AT-LP60XUSB Turntable Belt Replacement, Turntable Belt: step 1, image 1 of 1
    • Disconnect the power from the turntable.
    • Never work on the turntable while it’s plugged in.
    Ask FixBot
  2. Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 2, image 1 of 2 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 2, image 2 of 2
    • Remove the rubber slipmat from the turntable and place it to the side.
    Ask FixBot
  3. Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 3, image 1 of 2 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 3, image 2 of 2
    • Pull the metallic platter with the broken belt straight up to remove it.
    • Do not use excessive force when removing the platter, as it may cause damage to internal components.
    Ask FixBot
  4. Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 4, image 1 of 3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 4, image 2 of 3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 4, image 3 of 3
    • Flip the metallic cover upside down.
    • Remove the old belt.
    • Place the new belt around the circle on the bottom of the plate.
    • Ensure the belt lies flat and is not twisted or bunched up.
    Ask FixBot
  5. Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 5, image 1 of 3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 5, image 2 of 3 Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 5, image 3 of 3
    • Flip the metallic plate over and place it onto the turntable.
    • Align the hole in the center of the plate with the silver knob in the middle of the turntable.
    • Rotate the metal plate until the rectangular opening near its edge lines up with the gold knob in the top-left corner.
    • Use your fingers to pull the belt through the rectangular opening and loop it around the gold knob.
    • Be gentle while stretching the belt onto the pulley to avoid tearing or misalignment.
    Ask FixBot
  6. Audio Technica AT-LP60XUSB Turntable Belt Replacement: step 6, image 1 of 1
    • Place the rubber slipmat back on top of the turntable.
    • Connect the power to the turntable.
    • Turn the metallic plate on the turntable to confirm that the belt is spinning properly.
    Ask FixBot
Finish Line
Kenny
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 113
All Time: 553
